Help me figure out my CR
Old Jul 1, 2004 | 09:29 PM
dj haf's Avatar
i did a leakdown test on my car and this is what i got...
cyl 1: 180 psi
cyl 2: 180 psi
cyl 3: 180 psi
cyl 4: 180 psi
cyl 5: 178 psi
cyl 6: 175 psi
cyl 7: 180 psi
cyl 8: 180 psi
from the results i got, what would you say my compression ratio is? i know there's an equation on how to figure out the CR by just checking the compression on each cylinder, but i can't find it anywhere =\ thanks for the help
Old Jul 2, 2004 | 01:41 AM
transxtreme's Avatar
pshhh
Bro i got a big block waiting for you up here... Just come and get it.
Or ill bring it down when i come to see you some time this summer...lol
theres an eqaution somewhere let me find it...
Old Jul 2, 2004 | 01:11 PM
dj haf's Avatar
i know there's a fomula that you add all the numbers together and then divide them by another number to get an estimate of where your CR is. does anyone know what im talking about?
Old Jul 2, 2004 | 02:16 PM
aklim's Avatar
I have 10.8:1 with those numbers if that helps you.
Old Jul 3, 2004 | 01:31 AM
dj haf's Avatar
awesome. i was aiming for 10:5 to 1 so im pretty happy.
have 2 more questions... first, would it be wise to set the plug gaps to .050 with an msd 6al box connecting to a hypertech ign. coil (53k volts) with that kind of compression? and second, would it be a good idea to raise the car's fuel pressure if i have higher compression? thanks in advance
Old Jul 3, 2004 | 02:34 AM
aklim's Avatar
You could do that.
Maybe 1 or 2 psi but more than that, I would say you need to get the chip recalibrated.
Old Jul 3, 2004 | 11:42 AM
dj haf's Avatar
well, i have the HSR, comp cams 503 cam, and a 3000 rpm stall converter from edge racing converts waiting in my room to go into the iroc. when everything's installed, im going to get her dyno tuned so that she's runing the best she can thanks for all your help aklim
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
NewsBot
Sep 14, 2015 02:02 AM
