Rev limiter on 2-3 shift
Old Jun 10, 2004 | 11:20 AM
Jeff95TA's Avatar
'95 Trans Am w/3.73s, 4L60E, stock converter. Used the HPP3 to move the shift points down as far as possible, but I'm still hitting the limiter on the 2-3 shift. The 1-2 shift seems to be corrected. Should the HPP3 have taken care of the correction for the gears (i.e., do I have a tranny problem, not a programming problem)? Thanks.
Spoke with Hypertech and they say setting the gear ratio to 3.73 and setting the tire height should correct the shifting, shouldn't have to lower the shift points. Maybe my tire height needs tweaked?
Old Jun 15, 2004 | 03:03 PM
ScreamnChicken's Avatar
how is your tranny fluid? you could try getting it flushed and see if that helps it out. Mine did that too and my fluid was getting to be a pretty deep red. I kept driving it thinking i won't stress it too much and boom, my tranny went out and I am spending $1815 getting a new tranny built by Dana at Pro-built Automatics.
Old Jun 15, 2004 | 04:09 PM
94ZRiCeKiLr's Avatar
i think the first thing you should do is set everything back to stock as far as shift points and stuff go and do a tranny service....bad fluid COULD be your whole problem.
HarleyZ28
Oct 5, 2015 06:23 AM
Critter
Jul 13, 2015 05:51 PM
Flint78
Jun 21, 2015 01:28 PM
cristian1311
Apr 22, 2015 10:20 PM
Rbain
Sep 4, 2002 12:35 PM
