how do things just go out of adjustment, like timing or carburator
Old Jun 10, 2004 | 10:39 AM
CamaroZ28Coupe's Avatar
does it happen, like for example im having a starting problem currently and my engine cranks really funny and slowely, could this be a timing issue?, i diddnt touch anything timing related
Old Jun 10, 2004 | 11:01 AM
irocz383's Avatar
It is possible for the dist. to wander if you did not tighten the clamp down tight enough.
IF its tight and timing is right... just do a tune up. Fuel filter, plugs, wires, cap and rotor, maybe even a decarb.
Old Jun 10, 2004 | 01:12 PM
aklim's Avatar
iming can go out if the bolt comes loose. Carburator can go out if the fuel leaves too much varnish in the jets, etc.
Old Jun 10, 2004 | 01:56 PM
Sitting Bull's Avatar
It shouldn't turn slowly all of a sudden. Is your battery draining?
Old Jun 10, 2004 | 02:46 PM
Z28SORR's Avatar
Originally posted by irocz383
It is possible for the dist. to wonder if you did not tighten the clamp down tight enough.
Well they might "wander" but I dought the "wonder"!!
I know! I'll go crawl back in my hole now.
Old Jun 10, 2004 | 04:17 PM
irocz383's Avatar
Thanks for pointing out my inability to use the correct word
I've corrected it now
Old Jun 10, 2004 | 08:47 PM
i just bought a brand new battery, still does it, could starter be going? im going to try and disconect the primarys from the distributor tomarow so that i know that i wont get any spark at all
and then try to crank and see if it still goes slow
Old Jun 11, 2004 | 12:23 AM
Yes, a starter with bearings or brushes on the way out will drag on you. It could also be a corroded connection at the starter, assuming the battery connects are good.
Old Jun 11, 2004 | 07:36 AM
i think the connection on the battery might be bad, not corroded just not tight, i think that the little bolt is stripped becasue it wont tighten, i hope thats it becasue its 5 verses about 60 $$
any other possibilities that i can check out?
edman
Jan 25, 2015 02:41 PM
ScottZ
Mar 3, 2004 01:34 PM
Hal Fisher
Sep 14, 2002 09:36 PM
BLUESMAN
Aug 26, 2002 06:07 AM
