how to change out the ignition lock cylinder???
Old May 25, 2004 | 12:25 AM
93formula's Avatar
need help asap. i need to swap out the ignition lock cylinder, car is stuck in a walmart parking lot. can someone post directions please. the ignition turns but only if i wiggle it violently, otherwise it is stuck. it aslo has some play in it that it slides in and out of the housing.
Old May 25, 2004 | 12:33 AM
Dave89IROC's Avatar
pull off air bag, pull off steering wheel, pull clockspring, pull turn signal switch, unplug VATS wire under dash, snake wire up through column, remove retaining pin/screw, slide cylnder out,
reverse for install
Old May 25, 2004 | 02:24 AM
Jay-Roll's Avatar
reverse for install
Now that's one hell of a quick explanation. I wish I could sum things up perfectly like that. And only 8 min after he posted. I am surely impressed. Sorry I don't have any more help to add, that was obviously enough.
Old May 25, 2004 | 11:52 AM
93formula's Avatar
!!!!!!!!!!! i have to remove the steering wheel for the lock cylinder!!!!
thanks
but which one is the vats wire?
Old May 26, 2004 | 01:49 AM
93formula's Avatar
well $350 later, it wasnt the lock cylinder but a $30 ignition switch that sits above the steering column. oh well live and learn
DirtyDaveW
Dec 1, 2016 05:37 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jul 4, 2005 05:00 PM
