383 with SVO 42#ers 8psi ... need PE table
Old May 24, 2004 | 09:49 PM
LWM's Avatar
LWM
Well, I lost my fuel pressure, might be the pump, might be the FMU.
Now may be a good time to eliminate the FMU, so to that end I looking for suggestions as to how to tune for no FMU.
I have my injectors set at 47#s and that works just great.
With the FMU I was seeing around 58 psi of fuel pressure. Not a lot extra.
Would a good starting point be something like + 15% fuel in the PE curve from 4,500 rpm on up??
I do max out the MAF at somewhere around 5,800 rpm
Any suggestions appreciated.
LWM
Old May 26, 2004 | 08:33 PM
CJ's Avatar
CJ
Yeah that sounds like a good starting point. I usually do several WOT scans on my initial tune upping the rpms about 500 each time till I get to redline that way you can tell if you start to go lean without actually going really lean.
Just to let you know, without a FMU you will be very close to maxing out the injectors. The other day I was tuning a 355 with 8#s of boost and 42# injectors and his duty cycles were hitting 104%. His MAF was hitting about 460 not even maxing out.
MDZ28
11
Sep 24, 2015 09:15 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
