Idle timing /knock retard
Old May 23, 2004 | 02:52 AM
JDMZ28's Avatar
knock retard/ idle timing/Histogram questions
So let me get this straight, I set the timing at idle for a the lowest MAP value? I set it to 9.5 degrees and it gave me the highest value of 41.
Which knock tables should I desensatize to compensate for false knock? I lowered my extended spark tables to as low as 31 degree total advance and still picked up knock. Should I buy an LT4 knock module?
When I do a record session on Datamaster I notice that when I look at the histogram I see lean and rich values at the same airflow but at different rpm, I know I can't fix this by using the MAF tables because they don't depend on rpm. What table will allow me to fine tune this?
mikey4play
Mar 15, 2015 11:45 AM
Fatdog2
Feb 13, 2015 08:19 PM
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
