Can't get rear shock out
Old May 19, 2004 | 08:39 AM
CMYZ28's Avatar
The top mount is old and rusty, i've tried putting everything i can on top of it to keep the shaft from spinning, but still can't hold it in place. any suggestions??
Old May 19, 2004 | 09:09 PM
#7's Avatar
You could grind some flats on the sides of bolt/shaft and use an open end wrench to hold the shaft while loosening the nut after a good soak of penatrating solution. Or you could break out the recipricating saw and hack it off . Get more crafty?
That is assuming your replacing the shocks I guesss you did not say.Then it would not matter.
Old May 19, 2004 | 10:55 PM
phrozen's Avatar
we used a crescent wrench... but if yours is corroded I'm not too sure what you'd do.
wait do you mean the shock in the strut by any chance? I can't imagine the rears getting rusty. If this is the case we did something dangerous and cut the top bolt off with a dremel. make sure your spring compressor is fully compressed if this is the case.
*edit: I'm really stupid i had forgotten to notice the topic line... oh well, previous knowledge still holds true.
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
camaro98_speed
Apr 22, 2015 11:26 AM
siguy
Nov 27, 2014 10:07 AM
slothgrant
Aug 22, 2002 03:01 PM
