My 4inch vortech cold air intake
Old May 19, 2004 | 07:55 AM
[JFS]'s Avatar
http://jon.shoberg.net/CarStuff/Pics/coldair
I'm going to have one of the welds redone to give a bit more clearance but the above pictures will provide an idea. Its a 4inch elbow which will connect to 4inch ribbed-flex hose and then to the large K&N cone filter.
Solid 4inch is pretty rigid and a tight fit under the nose of the car also. Going with the ribbed powerflex hose allows a bit of adjustment. Plus the ribs are solid enough that they won't collapse under boost. The t-trim inlet is 3.75inches so this should be a bit of overkill.
Hopefully it will pull some air ...
Old May 19, 2004 | 11:20 AM
1st and goal's Avatar
Looks good
Marc
Old May 20, 2004 | 08:33 PM
[JFS]'s Avatar
Updated with a few more pics and the powerflex hose ... all 4 inch and ribbed to not collapse.
http://jon.shoberg.net/CarStuff/Pics/coldair/view
Old May 20, 2004 | 08:37 PM
EDS Z28's Avatar
That is a very good job.
I plan on doing basically the same thing, but using 3.5" tubing for the inlet to the V2. And it will be solid pipe all the way to the air cleaner, no flex hose at all.
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
