93 PCM question
Old May 18, 2004 | 10:19 PM
Gripenfelter's Avatar
93 PCM question
Which wire on the back of a 93 PCM is the tachometer signal output?
Or should I just hook up my shift light to one of the wires on the coil?
Old May 18, 2004 | 11:44 PM
Metlegleo's Avatar
Not sure where it is on the back of the computer...however you can pick it up next to the tach filter on the drivers side of car. Its the white wire on the four wire plug that goes to the Ignition Control Module on the front of the head.
Old May 19, 2004 | 09:05 AM
awesome thanx.
Old May 19, 2004 | 06:47 PM
Is it the white wire with the black stripe or the plain white wire?
Old May 19, 2004 | 07:26 PM
sseeya's Avatar
Gripe, not sure what color the wire in the factory harness is (the wire in my Accel DFI harness is solid white), but if the pin locations on the connector are lettered, it's "B"
Old May 19, 2004 | 10:50 PM
Metlegleo's Avatar
Solid white.
Old May 20, 2004 | 08:20 AM
Installed it.
Works perfectly.
Thanx again guys.
DirtyDaveW
Dec 1, 2016 05:37 PM
94Form
Feb 10, 2015 11:23 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Injuneer
Dec 15, 2014 09:36 AM
dreamer1q
Aug 20, 2002 11:19 AM
