coolant boiling out cap?
Old May 11, 2004 | 06:26 PM
Snoman73's Avatar
i just replaced my plugs n wires today, gapped them right, did everything right, it went very well, i drive my car around this afternoon and it drives great (but i dont think to look at my temp needle) well i get home, and go inside, 45 minutes later my dad says somethings leakin outta my car, i go out and there is coolant runnin all down the carport, from what i can tell, it boiled over and outta the coolant cap, WTF is goin on? any ideas? im pretty sure it overheated, but why now? after the change, didnt do it before? thanks
Old May 19, 2004 | 05:00 AM
HBHRacing's Avatar
have you ever let it sit that long at idle before? you need to see if the fans are coming on. what cap was it comong out of? radiator cap or overflow cap?
Old May 19, 2004 | 07:56 AM
Snoman73's Avatar
yep, fans are comin on, came out of the coolant resevoir cap, even tho i had it screwed on, it hasnt done it again since, it drives fairly normal, but the needle does go up after i drive it for like 30 minutes, so i dunno what it is, any ideas
Old May 19, 2004 | 08:42 AM
Lt1 and Ls1's Avatar
How hot did it get when you were driving it?
Old May 19, 2004 | 03:22 PM
Snoman73's Avatar
well, im not really sure, when i looked (after the car was off) it was like near or past the 3rd mark, and it usually stays near where it was when i turn it off, so it def. was hot, but now when i drive, itll get to half way, sometimes a lil more then halfway, it usually dont do that, im afraid if i went anywhere and had to drive more then 30 minutes that it would get hot again, if though i only drove it like 20 when it overheated, any ideas
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
heus
Sep 8, 2015 12:01 PM
