Adjusting fuel pressure affect air fuel ratio?
Old May 9, 2004 | 07:20 PM
rkussy's Avatar
I have an adjustable fuel pressure regulator with 30# svo injectors & other mods. Can I change air fuel ratio by increasing or decreasing the pressure? I thought that I read somewhere that the computer will overide any adjustments.
Old May 10, 2004 | 06:45 PM
PoorMan's Avatar
It will only have short term effects from what I have read. The only permenant way is to change the injector constant in the PCM. For example, I was running rich across the board. BLM's 112-120. Since I was running stock 24lb injectors I changed the constant to 27lbs and my blms locked in at 126-128 and stayed there. Basically, increasing the constant leans the car out and decreasing it makes it richer.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
armedtrigger
Feb 24, 2015 08:30 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
