Oxygen sensor replacement
Old May 8, 2004 | 07:02 PM
cop_camaro's Avatar
OK Gang;
I want to repalce my Oxygen sensor as my 2000 LS-1 has 102k
miles.
What improvement, if any can I expect?
How difficult to do?
How many required?
What's the cost?
Can these sensors cause the service engine light to come on.
Any info greatly appreciated.
"Ray"
Old May 8, 2004 | 07:39 PM
MasterEvilAce's Avatar
Re: Oxygen sensor replacement
Originally posted by cop_camaro
OK Gang;
miles.
How many required?
What's the cost?
"Ray"
If your O2 sensor is bad, it'll give incorrect readings, causing your car to run lean/rich
Don't know how hard.. should be an unscrew/rescrew in new one .. (make sure the car is hot, when you do it, to make it come out easier), there's ... 2 on 4th gens, i believe... MAYBE there's 4.. i'm not sure
cost? don't know.
Yes, they can cause SES light to come on
O2 sensors are supposed to last 20-30,000 miles
I get 12MPG on my 87 camaro, and I have reason to believe it's somewhat the O2's problem, too (140,000 miles)
Old May 8, 2004 | 08:35 PM
DARK AGE 53's Avatar
You can but an o2 sensor socket which is a good idea, it works better if the pipes are cold and there are four o2's.
Al
Old May 9, 2004 | 03:22 AM
mullettour's Avatar
All you need to replace an oxygen sensor is a 7/8" wrench. There are 2 before the cats and 2 after. I wouldn't bother changing the 2 after the cats if I were you.
Old May 9, 2004 | 07:09 PM
LT-14me's Avatar
Is there a specific trouble code that will tell you which sensor is going bad? My car is running very rich and i have about 70k on my car.
Old May 9, 2004 | 10:27 PM
yes, i believe
It'll say Bank1 or Bank2, i THINK...
if it returns a code about the CATS, then either your CATS is bad, or the O2 AFTER the CATS is bad
i believe
Old May 10, 2004 | 02:27 AM
GoFast908Z's Avatar
Member
if the pipes are hot, then the cats are much hotter at the same time. Good luck doing that without burning yourself.
My after cat, O2 sensors aren't even in the exhaust anymore. I just zip tied them out of the way until I could make a hole in the pipes for them. I have a SES light sometimes because of it, but my fuel air mix on the dyno is perfect. Is that a problem?
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Fatdog2
Feb 13, 2015 08:19 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
