What PE values are you running?
Old May 8, 2004 | 01:23 PM
will62085's Avatar
Just wondering what motor setup and what PE VS RPM values people are running in LT1edit...i thought it seeemed strange that gm made the pe values fall off so much over 5600 (i know thats the redline, but still...kinda wierd)...just curious to what everyone else is running up there
Old May 9, 2004 | 09:06 AM
PoorMan's Avatar
Here are mine. I don't know what the A/F is with these but my O2 readings are still in the 900's.
http://bellsouthpwp.net/t/r/trna/oth...E%20Tables.jpg
Old May 9, 2004 | 07:05 PM
97Z-M6's Avatar
http://f1.pg.photos.yahoo.com/ph/vin...eron/my_photos
heres mine the A/F ratio is about 13.1
Old May 10, 2004 | 08:06 AM
PoorMan's Avatar
huh, on paper it looks like I am running about 5% leaner than you. Since are setups are different who know though.
Old May 10, 2004 | 05:17 PM
97Z-M6's Avatar
look under the column that says 80 degrees
here is mine
here is yours
you are running rich and lean in different rpm ranges.
Old May 11, 2004 | 09:50 AM
PoorMan's Avatar
Are you adding the two percentages and then adding or subtracting that from 14.7?
Old May 11, 2004 | 04:53 PM
97Z-M6's Avatar
here is the formula
WOT AFR = 14.7 / (1 + %Change vs Cool/100 + %Change vs RPM/100)
16/100 is .16 +1 =1.16
+%Change vs RPM/100) -8.0 / 100 = -.08
now add these 2 numbers together and you get 1.08 now divide that by 14.7 and you have 14.7/1.08 =13.611 your a/f ratio
Old May 11, 2004 | 05:39 PM
PoorMan's Avatar
Oh yeah, it's in my spreadsheet for PE dyno tuning. I never looked at the formula that was in that cell. It's the same one.
DirtyDaveW
Dec 1, 2016 05:37 PM
redzed
Aug 31, 2002 01:00 AM
Lions3
Aug 27, 2002 01:33 PM
