shaving weight?
Old May 4, 2004 | 08:51 PM
johnnyt's Avatar
shaving weight?
looking to shave weight without removing suspension parts. i would rather replace the parts with lighter ones. any thoughts or suggestions?
thanks john
Old May 4, 2004 | 09:55 PM
PatriotTA's Avatar
Carpet.
I know they make lightweight carpet. Alternatively, you can just pull out your padding and put the carpet back down. I still have 100% stock carpet in mine, but it is pretty damn heavy, I'll tell you that much.
Also tubular components, such as k-member especially. Check out www.bmrfabrication.com
Old May 4, 2004 | 10:58 PM
Bone Daddy's Avatar
BMR tubular k-member and A-arms will cut a good amount of weight. So will removing the stock interior seats (front/rear) and adding light plastic racing seats. Switching to a fuel cell with a stripped rear trunk will also save a few pounds. Then there is the slimfast diet.
Old May 4, 2004 | 11:00 PM
Xride's Avatar
Originally posted by PatriotTA
Carpet.
all carpet with all sound deadning only weighs about 35 lbs.
as said tubular K and lower control arms will save you about 60 lbs I think it was, and hte K member will alow for a much easier long tube install.
unfortunatly I dont know of any other parts that will have a significant difference.
if someone made a lighter crush bumper (or what ever that part that is under the facia with the honeycomb part on its called) that would be nice, cause it weights like 65lbs.
Old May 4, 2004 | 11:09 PM
With regard to suspension components, consider the ones made from chrome moly. They will generally weigh 25-35% less than a corresponding mild steel part. Same with a roll bar or cage - chrome moly tubing saves up to 40% of the weight.
As far as the crash pads in the bumpers, don't know about the Z's but on the Formula/TA the front pad with steel support bar is only 19#. Rear pad/support bar is 20#.
Old May 4, 2004 | 11:25 PM
Xride's Avatar
is it? then what did I take off my salvage? it was HEAVY
Old May 4, 2004 | 11:30 PM
Bone Daddy's Avatar
Just to be a wiesenheimer and since my front/rear crush supports are removed, I went and weighed the two... Results? The front bracket/cushion wighed 30#'s and the rear 25#'s. I used a fish scale, (don't ask) and both parts. Yes, I bore easily.
Old May 5, 2004 | 01:46 PM
I can only tell you what mine weighed on a shipping scale when I removed them.
Old May 6, 2004 | 10:07 AM
mongse_1's Avatar
Fiberglass hood, race seats, knock out the A/C, smaller diameter torque converter, aluminum driveshaft, lightweight wheels
Old May 6, 2004 | 10:57 AM
trax's Avatar
LG Motorsports makes aluminum double rod-ended LCA's and a matching panhard rod. They are ridiculously light (~2 lbs or so per LCA), yet will stand up to the beating of a World Challenge race. I will be moving up to these once I'm done with the rest of my suspension.
brothaslide
Jan 9, 2016 12:11 PM
95chwagon
Oct 16, 2015 12:24 PM
NewsBot
Sep 14, 2015 09:20 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
