Zaino user's >>
Old May 4, 2004 | 07:51 PM
Patriot's Avatar
Zaino user's >>
Do you wash your cars to get the streaks out or am I putting this stuff on wrong .
No matter how many coats of Zaino I put on it , I have to wash the car before a car show to make it look right .
Old May 4, 2004 | 07:57 PM
Darth Xed's Avatar
Sounds like you are using too much polish... try less.. it REALLY goes far.
Also, a nice Z6 wipedown should clean up any streaks... just use it sparingly too.
Old May 4, 2004 | 09:02 PM
moparman's Avatar
Less is best with Zaino. You just barely want to see it.
Old May 5, 2004 | 07:52 PM
Kevin V 2002 SS's Avatar
My son can do one entire application with just a little more than 1/4 oz., I use about 1/2 oz. per application.
Applying it too thick is about the only way you can have a problem using Zaino.
Old May 6, 2004 | 09:41 AM
SSMOKEDU
Guest
Posts: n/a
Using too much....
I had the same problem the 1st time I tried Zaino, and I told my distributor about it, and that WAS the problem.
Old May 6, 2004 | 08:33 PM
Patriot's Avatar
Thankx all for the replies .
Old May 7, 2004 | 12:51 PM
mike996's Avatar
Does Zaino have a website?
Old May 7, 2004 | 12:54 PM
SLIMJIM's Avatar
Zaino
Old May 10, 2004 | 02:08 PM
350 HRSS's Avatar
Yep, you are using way too much. You should barely be able to see it on a car. It will be weird the first couple of times, but you really need to use less.
Check out Sal's tips on the Zaino website. If you follow those, you can't go wrong.
Also, make SURE you are using a WHITE 100% COTTON MADE IN THE USA towel. This has a lot to do w/ wax coming off correctly.
GOOD luck!
Old May 12, 2004 | 07:41 AM
hcvone's Avatar
How much Zaino do you use to do your car? You should be able to get 2-3 coats per oz, many f-body owners get 3-4 coats per oz.
marlar98
Sep 12, 2018 07:18 AM
2QUIK6
Sep 17, 2016 02:31 PM
92_RS_305
Sep 8, 2015 07:47 PM
maverickmk
Sep 1, 2015 09:17 PM
mrwz28
Jul 8, 2015 09:11 PM
