Need help with circuit
Old Apr 30, 2004 | 08:12 PM
MikeStank's Avatar
I burned up a power inverter that takes 12vdc up to 280VAC @1500HZ. When i took it apart, its not complicated except i dont' know what kind of transistor I need or capacitor. It consits of 2 resistors 1 capacitor, 1 diode, 1 transistor, and the small transformer.
Any help would greatly be appreciated.
Old Apr 30, 2004 | 08:48 PM
LS1 RULZ's Avatar
You need to get the component values and/or identification codes from the parts you need to replace. Resistors use a color code to indicate value. Capacitors use a numeric code to induicate value. The diode and transistor should have their ID numbers on them.
Old Apr 30, 2004 | 08:52 PM
MikeStank's Avatar
yea i got the capacator values and resistor values, the transistor is completely black And that is probably what needs replaced
Old Apr 30, 2004 | 09:06 PM
LS1 RULZ's Avatar
You might try contacting the maker and asking them for a schematic of the circuit.
Old Apr 30, 2004 | 09:12 PM
MikeStank's Avatar
already done
Old May 1, 2004 | 12:41 PM
MikeStank's Avatar
Its not a matter of just swappin pieces I've had 1 EE course in college and i sorta hated it, it only teaches op amp operation anyways nothing about transistors.
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
z28cam1993
Sep 9, 2015 04:08 AM
4586
Aug 24, 2015 11:04 PM
