Finaly got my FM5s...How do i remove the Clear Coat?
Need to remove the clear coat and polish the whole thing. I am using the Aircraft Stiper but its not working too well... any ideas what else to try?
How are you using the Aircraft Stripper?
That's what we used on my buddies WS6 wheels and it work perfectly.
This is the kind we used...
http://www.handsontools.com/store/sh...roduct_id=8952
Hmmm...well, what we did with his was sprayed it on pretty thick, and then let is sit for about 15-20 minutes outside - not in direct sunlight.
After that we used a soft plastic scraper (aka. bondo blade) and scraped all the gunk off. Then we washed them off with a waterhose and terry cloth towel.
After about 3 rounds of this they were completely stripped. Wasn't real simple - just time consuming mainly though.
ok, got one of them stripped mostly...now they have bunch of stains on them....what polish compound should i use? The gool old mothers polish isnt cutting it. Need something stronger..any suggestions?
If the Mother's Billet Polish doesn't work (note - the BILLET polish - it's a little more "polish" than the regular) then you will probably have to go with the bars.
Eastwood has a nice variety - but their site isn't working today for some reason.
Have fun with that - just get you all the proper wheels, proper bars of polish and go to town - expect to spend some time with them.
well im jumping in this post cause i am having problems with my iroc wheels, what should i do to my aluminium i have 25 percent of the clear coat off, but the alumminum ow has a million scratches on it cause i used a wire wheel, what should i continue wwith and how do i make my painted gold portion shine
Here's a guide from Eastwood.
carguyshu
Jan 22, 2017 11:19 AM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
