Biggest tranny cooler on an LT1?
Old Apr 27, 2004 | 08:56 AM
94Zpower's Avatar
What is the biggest trans cooler that will fir on a LT1 car?
does 10"x15 1/2"x3/4" sound like it will fit??
Thanks!
Old Apr 28, 2004 | 09:09 AM
94Zpower's Avatar
TTT
Old Apr 28, 2004 | 04:14 PM
GreenDemon's Avatar
It's not really a question of if it will fit but where it will fit. I assume you are mounting it near the radiator so you don't have to do too much line changing/fabricating? It sounds like it will fit to me, but I'd go measure to make sure- if there's room most likely the problem won't be getting it to fit, but getting it mounted properly and getting it to stay there.
If you run into too many problems you can always get one of the coolers with the fan and temp sensor attached to it, run some lines and put it anywhere you want...
Old Apr 28, 2004 | 09:41 PM
Spinner's Avatar
If you remove A/C you can fit a pretty decent sized one in there.
Old Apr 29, 2004 | 02:30 AM
BiGGinZ's Avatar
The one I have on my car is about that size and it fits fine. I think mine might be a little bit littler then that though.
Old Apr 29, 2004 | 08:47 AM
94Zpower's Avatar
Thanks for the help guy's!
RedLineRev
Jan 23, 2003 03:51 PM
Javier97Z28
Sep 8, 2002 07:23 AM
chesee48
Aug 22, 2002 08:28 AM
96z
Aug 2, 2002 09:00 PM
Dragonballz28
Jul 28, 2002 04:45 PM
