unhooked battery now radio wont work how to unlick code?
Old Apr 18, 2004 | 12:25 PM
bluecmaro96's Avatar
my radio says loc since i disconnected the battery, how do i find the code out so i can listen to my radio?
Old Apr 18, 2004 | 01:17 PM
mullettour's Avatar
Take it to the dealership. There is a code they can put in it to unlock it and it shouldn't cost you anything. I had to do it on my parents suburban and it only took about 2 min.
Old Apr 18, 2004 | 05:45 PM
Onez4u2bn's Avatar
Do a search man. They said $75 here to do it. Ill look to find it also. I have it printed out. Ill type it up if i have to. Dont pay that much for it.
Old Apr 18, 2004 | 05:53 PM
so you know how to tell me to unlock my radio? that would be great, couldnt find anything exact on mine
Old Apr 18, 2004 | 06:22 PM
moparman's Avatar
Use Mr. Searchy and search for "unlock radio". You should find many threads with
the directions for doing it.
Old Apr 18, 2004 | 06:44 PM
mullettour's Avatar
I did a search on google and found this.
First, press and hold presets two and three for a few seconds. Three digits will come up on the display. These are the first three digits of the factory unlock code.
Press the AM/FM button on the unit and another three-digit number will read out. These are the last three digits of your code.
Call 1-800-537-5140. You'll be asked for a dealer code, enter 206053. Enter this number and then press the asterick (*) button.
Now enter the six-digit code that you got from your stereo, first three digits first, then the last three. You will be given a four-digit response code. Make note.
In your car, hit the MN button and 000 will appear on the display. Press MN again o make the last two digits agree with your code. Press HRto make he irst one or two digits agree with your code. ress AM-FM after you have confirmed that he code matches the code you have written down. The display will show sc, indicating the raio is now operable and secure.
You should be unlocked!
If that doesn't work I don't know what to tell you.
Old Apr 18, 2004 | 08:33 PM
see the owners manual says hold 1 and 4 i tried that and nothing happened, how can you disable this crap like say if i put in an aftermarket cd? or just disable for stock one?
Old Apr 18, 2004 | 09:09 PM
Onez4u2bn's Avatar
MULLET IS THE MAN! Thats the one Blue. Use that and you will be set. Any problems let us know!
Old Apr 18, 2004 | 10:10 PM
00LukeyWS6's Avatar
What mullet said, the reason why the dealership usually charges .5 to 1 hr for code is because they have to pull the radio. If you want you can try calling the dealership where the car originated from and see if they have the code in the system.
Old Apr 19, 2004 | 03:28 PM
after work i went to the dealer, the service manager sat in the car pressed 2 buttons and it came up 006 he said ill be back, he then came back out entered the factory code 1136 i believe then pressed mn then pressed hr and the radio worked, he said i can now make my own code up took 3 minutes and didnt charge anything and didnt remove sterio
liamcg97
Nov 25, 2019 05:55 PM
Gtpguy
Jan 26, 2015 04:50 PM
97z28k&N
Jan 9, 2015 04:58 AM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
