? about sump in gas tank and fuel system
Old Apr 11, 2004 | 12:45 PM
DTABFORMULA's Avatar
Angry ? about sump in gas tank and fuel system
i got a sump in my tank and im going to run -10 fuel lines.. my ? is the sump has two holes for fittings.. is the right one for the fuel line that goes to the pump,? and the left hole in the tank, is that for the return coming from the regulator??? i was wondering this cause i dont know if the regulator will push all the fuel back into the tank, is that what the two holes in my sumped gas tank is for..where would the return line from the regulator go????
any help
shawn
Old Apr 11, 2004 | 12:53 PM
Mike383LT1's Avatar
return lline
i ran all new braded stainless steel lines when i did mine i used the factory feed line as my return line and ran just one line from the sump i feed my pump with a 12an line and ran a 8an feed and a 6an return
Old Apr 11, 2004 | 01:09 PM
ok that dont help at all, =)
i have no fuel lines at all right now, i got my gas tank is sumped already, but dont understand how to run the fuel lines, there is 2 holes on the sump.. i was wondering if the other hole is where the return goes??? the othe is for the line to the pump of course..
but i dont know where you put the return... is that what the other hole in the sump is for??
shawn
Old Apr 11, 2004 | 04:23 PM
Mike383LT1's Avatar
extra line
no! you can not return the fuel to the other fitting you must return the fuel to the top of the tank the extra fitting can be used for a dedicated nos fuel system or you can plug it some of the carb guys will run two fuel pumps to keep the volume up but with an electric fuel pump that is not nessasary thats why i converted my origanal factory feed line coming out of the top of the tank as my return it will accept a 6an coupler
Old Apr 12, 2004 | 08:02 AM
Ditto...... The two outlets in the weld-on tank sumps are so you can hook up two pumps, if necessary. You generally weld a connection for a return line to the top of the tank. Also, don't go overboards on line sizes.... the larger the supply line from the pump to the rails, the more force you have pushing back on the pump on a hard launch, and the larger the sudden drop in fuel pressure will be on launch, just when you need max fuel pressure/flow. I've run 800HP through a -6AN supply and return, and I've seen a similar system support 1,000HP. You do want to run at least a -10AN suction line to the pump.
Old Apr 13, 2004 | 05:05 PM
that helps....
thanks
Old Apr 13, 2004 | 06:56 PM
PatriotTA's Avatar
I don't mean to hijack the thread, but do any of you have a pic of your tank, out of the car? I'd like to see the return line at the top.
Old Apr 15, 2004 | 12:40 PM
you didnt hack it....me too if somebody has pics..let me know also
thanks
Old Apr 15, 2004 | 01:33 PM
Mike383LT1's Avatar
return line
sorry tank is still in car the factory feed line is the same as a 6an line slide over tube sleve and tube nut put on a single flare and your set up for stainless braided line keeps it clean no welding on the top of the tank
Old Apr 15, 2004 | 02:20 PM
If you have a stock recirculated tank.... e.g. 4th Gen... you have a return line connection on the module at the top of the tank, you can use that... no need to weld anything on. If you've done away with the factory pump module and fuel lines, that's when you need a welded connection. If you've deleted the fuel pump module, you could just weld the return connection to whatever sort of cover you made to cover the hole where the stock module goes. You could probably get away without welding, if you used an -AN "bulkhead fitting" with good, fuel resistant gaskets.
Maybe I'm missing the point here, but it seems to be getting over-complicated. I use the stock module to hold an upgraded Bosch intank pump, and a welded -10AN fitting, and internal screen for the bottom/rear of the tank to feed a 2nd Bosch pump that only runs when the nitrous system is armed. The stock fuel lines have been replaced with -6AN on both supply and return. Like I said, easilly supports 800HP including 300HP of dry nitrous.
Old Apr 15, 2004 | 02:51 PM
Mike383LT1's Avatar
sump
i am not running an intank pump but i kept the factory sending unit im pulling thriugh the sump into a aeromotive eliminator pump for a return i modified the factory feed lin (no longer conected to anything) and converted it to 6an stainless
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Deadbolt24
Jan 19, 2015 01:29 PM
blac94Z
Nov 24, 2014 07:12 PM
