3.73's or converter, or both?
Old Apr 10, 2004 | 01:22 PM
speed_demon24's Avatar
I have 3.23's right now, and I'm debating on just gettin a vig 2800 and keepin the 3.23's so i don't kill my gas millage, or should I go with 3.73's and the stall? I plan on doing h/c down the road too if that makes a difference.
Old Apr 10, 2004 | 01:24 PM
LT1Squirrel's Avatar
i'd suggest getting the stall first....you'd see more improvement with that over gears, plus youd run lower on the highway still
Old Apr 10, 2004 | 02:24 PM
LilJayV10's Avatar
Definatly a stall, you will pick up alot more time than with a gear swap, and if you get a good converter, like a yank or a vig, you don't need as deep of gear because of the insane tourqe multiplication you get from a 9.5 converter.
Old Apr 10, 2004 | 06:58 PM
Whats the stall/ratio on the vig, and how efficient is it, because I don't want to loose any topend.
Old Apr 10, 2004 | 09:31 PM
LilJayV10's Avatar
I believe the STR is 2.2-2.5, as far as loosing some up top, that will depend on how high of stall you get, atleast thats the way it was explained to me. Go to www.pro-built.net or call Dana, he's a great guy and will answer any question's you have. He is a little conservative on stall speed but it comes down to how you drive the car. I was going to up my stall to around 3300, but after talking to him yesterday he talked me out of it, mainly because 1, I have such traction issue's now, and since I like the way the converter performs, he said if I did go higher I would notice some slight mph loss up top, but it's like anything else with cars, you can't have everything.
Hope this helps some.
Jason
Old Apr 10, 2004 | 10:35 PM
BiGGinZ's Avatar
The best thing would be to get gears and a stall, but you would be fine with just the stall. I say just the stall or both.
jbert55
Aug 3, 2015 05:49 PM
detroitmuscle
Jul 31, 2015 04:21 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
