Will swapping rear-ends interfere with my speedo/tach???
Old Sep 17, 2002 | 12:54 AM
stanghunter211's Avatar
Hey guys. Just got a deal on a 3.27 posi unit for my 86 Z. I have been wanting to do this for a while now, and I wanted to know if it will affect anything, and if so, what will I have to change! Thanks guys!
Will
Old Sep 17, 2002 | 07:35 AM
88 427 Camaro's Avatar
That depends. Are you talking about just the posi unit or the complete rear end or????
If you currently have a 9 bolt rear, the posi unit will fit, but it is a series 3 type unit and will only work with 3.23 to 4.10 gear sets. If you have 2.77 gears, they will not work with the series 3 posi unit.
If you have a 10 bolt rear, the posi unit will not work at all.
If you want to replace complete rears, yes, they are directly interchangeable.
More inforamtion on the 9 bolt is available at www.9bolt.com or www.diffsolutions.com
Miles
Old Sep 17, 2002 | 06:45 PM
91-RED-WS6's Avatar
Miles
Oh, man... You didn't read his topic very well, did ya???
Yes, it will mess up your speedo. The speedo drive comes off the transmission. Bigger tires/wheels and changing gear ratios will ALL affect your speedometer. Since 3rd gens are gear driven, you may not be able to change this.
Good luck w/your decision!
Old Sep 17, 2002 | 11:46 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
What gears do you have now? If you have 3.23's, you'll be fine. Anything else and you'll need to change the speedo gears in the transmission. Its really simple.
Old Sep 18, 2002 | 12:11 AM
kevin!!!
Could you please help me with changing the speedo gears in the tranny. I wanna buy the rear end because its a good deal and I proly wont put it in for a while yet. Anyway, I have the stock 2.73 non-posi setup on my Z/ I will be switching to 3.27 posi disc rear. I will have the tranny out for a rebuild when I but the new 350HO in. So if there is anyone who could help me out a bit, that would be appreciated. I think these gears will be a nice little switch from what I am running now!
Thanks all!
Will
Old Sep 19, 2002 | 01:20 AM
Kevin91Z's Avatar
Check out the tech section at http://www.sethirdgen.org/ They have an article on how to change the speedo gears in an automatic tranny. Your tranny rebuild shop should be able to handle this as well. If they cant, find a new one.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
