What else can I do to get more power?
Old Apr 8, 2004 | 01:21 AM
Ex4.6Owner's Avatar
Well the guy that bought my old Mustang has been dumping some cash into it so it can beat my LS1. I don't know about you guys, but I know I don't want the car I sold because it didn't have LS1 power beating my new LS1. I have all the mods in the sig. What else can I do other then headers, cam, and heads? I plan on getting headers in July and heads and cam next summer. What can I do this summer to boost Horsepower and lower 1/4 mile time? All advice welcome!
Old Apr 8, 2004 | 01:44 AM
mullettour's Avatar
nitrous
Old Apr 8, 2004 | 03:01 AM
chpmnsws6's Avatar
Originally posted by mullettour
nitrous
Old Apr 8, 2004 | 03:02 AM
chpmnsws6's Avatar
pro 5.0 shifter
t/a rear end girdle so you don't mess it up
put a pipe thru the cats
SSRA, smooth bellow
learn how to powershift if you can't right now
Old Apr 8, 2004 | 07:14 AM
teke184's Avatar
since you're planning headers, why not just gut gut the cats now.
i also agree with the shifter, will make you a much better more proficient shifter.
ported throttlebody
160 stat and TB bypass
anything to get more/better traction. like lower control arms, torque arm bushing, relocation brackets
Old Apr 8, 2004 | 07:25 PM
Nsty98LS1's Avatar
nitrous
Old Apr 8, 2004 | 09:38 PM
80TA's Avatar
You want more power fast..cutout..and you could add headers
with or without cats.And a cam is pretty easy in the ls1s.
And not much else is there..ported tb maybe a couple of hp,you already have the ls6 intake.160 stat and tb bypass won't do much really.
After that if you have m6 its gear time 3.73 or 4.10 and good stall like 2800 to 3500 if you are auto.And of course nitrous works very well as do superchargers or turbos.And heads work ok too.
Old Apr 8, 2004 | 10:38 PM
Ex4.6Owner's Avatar
I've heard that if you put 4:10's in a new F-bod with Nitto Dr's your going to run into the problem of snapping driveshafts and rear ends?...I def. want to upgrade to 4:10's soon but I don't want to have to mess around with the problems that I heard come with them.
As far as a supercharger ( should be in the supercharger section I know ), won't that mess up your internals pretty good if your running too high PSI???
Old Apr 8, 2004 | 10:43 PM
Black01_Z's Avatar
Not with Nitto tires. Theyre sticky tires on a stock car. But put them on a car with a stall or gears and time for new tires.
BTW get headers.
Old Apr 9, 2004 | 03:17 PM
elderon's Avatar
There aren't many cheap mods left. Get smooth Bellows and do the TB bypass (every little bit helps). Perhaps porting and polishing your throttlebody (or buying one already done on ebay). You might find a used Hypertech for under $200 - get a 180 thermostat with that. You can try the power tuning - it MIGHT help, might not (I havent been able to tell since my times are too inconsistant at this point) - but u would need it for the thermostat swap. Race on a 1/4 tank of gas and ditch the spare and jack. Good luck!
Old Apr 9, 2004 | 03:35 PM
6speedZ28's Avatar
Nitrous....LS1's love a nice shot of nitrous, oh and stay away from Hypercrap programers.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
