View Poll Results: How much juice on the stock bottom, reliably ~ Assuming engine is in good shape.
100
9
21.95%
125
12.20%
150
19
46.34%
175
12.20%
200+
7.32%
Voters: 41. You may not vote on this poll
N20 On Stock Bottom ???
Old Mar 21, 2004 | 01:52 PM
HardcoreRM125's Avatar
How many of you guys are spraying on the stock bottom? It seems like LT1's can take a decent amount of spray reliably if the kit was installed rite. What shot are you spraying? ( Poll )Any problems caused from spraying?
Old Mar 21, 2004 | 02:15 PM
Kain's Avatar
A buddy of mine and I sprayed a 100 shot for awhile. When we took apart the motor to do cam swaps, there wasn't a pit or ding in any of the pistons.
Old Mar 21, 2004 | 02:56 PM
96LT14u2Nv's Avatar
it is a crap-shoot. some last, some dont. how many miles? i would do 100 just to be safe.
Old Mar 21, 2004 | 03:47 PM
chesee48's Avatar
If you do it the right (check your spelling ) way and use all the safety things, a 100-150 is do-able. i'd stay on the lower end towards 100. But do headers and all the other bolt ons FIRST. Dont use n20 as a cheap way to get fast, like the majority of people do when they dont have other needed mods done first.
Old Mar 21, 2004 | 04:49 PM
RacinLT1's Avatar
i sprayed a 150 for well over a year and a half. then 175 for another 6 months.
Just recently pulled it apart and NO problems at all.
just make sure the tune up is spot on and the fuel/ignition systems are up to snuff.
Old Mar 21, 2004 | 05:28 PM
nitropatch's Avatar
i did 150 on mine for a couple of years then pulled it apart NO problems and made the the internals forged and got a better cam.
150 will be fine but most people run better ad fast times with a 100 shot so bigger isnt always better.
Old Mar 21, 2004 | 05:35 PM
TransAmGT's Avatar
150 all the way!
Old Mar 21, 2004 | 06:27 PM
rpm4lalo's Avatar
150 Shot with a new in-tank fuel pump should be fine.
Old Mar 21, 2004 | 10:18 PM
262guy?'s Avatar
Start low like 75 and work your way up when you feel comfortable. With good fuel and spark 150 is safe.
Old Mar 22, 2004 | 07:24 AM
Derrick Redd's Avatar
NX 175 shot.
Old Mar 22, 2004 | 10:52 PM
formula383's Avatar
I ran a 150 NX shot on my car for a while with no problems.
Just bought a TNT kit and plan on running 100 for a while then going to a 150 shot. Possibly 200 at the end of the year.
I would get the new fuel pump before adding the nitrous though. Might not be necessary but I would rather play it safe.
Old Mar 22, 2004 | 11:16 PM
tobin's Avatar
Know someone who put 200 shot on stock everything. ran the engine from 50K to 150K with no probs on the stock engine. Took the engine out to replace with four block main he had been building. the stock engine still ran awesome even after 100K with 200 shot runnnin through it.
Just make sure you don't run lean!
T
Old Mar 23, 2004 | 09:28 AM
formula383's Avatar
Two of my friends have ran a 200 shot on a stock bottom end. Both ran without any problems.
I am going to be playing it safe with my n2o setup. I am going to install a new fuel pump, 30# injector, and a window switch when the kit is installed.
D1SC383LT4
Jan 1, 2016 01:56 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
sscott
Jan 17, 2015 04:30 PM
Killer94z
Jan 13, 2015 12:06 PM
