First things to do for a performance tune?
Old Mar 21, 2004 | 01:45 PM
PatriotTA's Avatar
I recently picked up a copy of Tunercat and have changed a few little things, but haven't really got into the tables yet. Among other things, I just installed some Hooker LTs and I'm waiting for nice weather to get the dual exhaust installed. My question is what should be the first tables to edit for a little more performance? More spark advance? Lean the car out? Where is a good place to start, and what tables should I look in?
Old Mar 21, 2004 | 04:54 PM
97Z-M6's Avatar
before you edit anyhting you need to get some sort of scanning equitment. and the best out there is datamaster.
Old Mar 21, 2004 | 10:00 PM
PatriotTA's Avatar
Forgot to mention, I have datamaster as well.
Old Apr 19, 2004 | 01:46 PM
scoobysnax83's Avatar
ttt, this is my situation as well...
Old Apr 19, 2004 | 01:52 PM
OpCode's Avatar
the way i do it goes like this..
make sure everything is A-OK.
no knock, IAC right, TPS is set etc..
then start w/ the 0% TPS spark adv..
set it to get the highest MAP(most vaccum) uses less fuel ..
if you have a dyno run w/ your current mods use the dyno tuner sheet(excel xls)
to get 12.6-12.8 AFR
then start w/ the timing..
then do shifting if its an A4.
later
Old Apr 19, 2004 | 08:54 PM
PatriotTA's Avatar
OpCode, can you explain a little more? I don't quite understand what you mean by
"then start w/ the 0% TPS spark adv..
set it to get the highest MAP(most vaccum) uses less fuel"
Old Apr 20, 2004 | 10:17 AM
OpCode's Avatar
Here
thats the page i used to start with.
in tunercats the table is named "Closed TPS ADV" or something like that, im at school so i dont have tunercats in front of me..
hope that helps
PS.
it find the lowest MAP(Highest Vac.)
heres a link just for idel SPK Adv here
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Hal Fisher
Sep 14, 2002 09:36 PM
