Zexel Torsen
Old Mar 19, 2004 | 04:23 PM
MRBoss429x's Avatar
Zexel Torsen
Howdy folks. My posi recently shat the bed and Im looking for a new one. Ive been looking at the Torsen Zexel unit from SLP. Its only $99.99, which looks really, really good to me compared to the $300.00+ eaton unit. What i would like to know is, is this a good means of differential replacement. Its for a slightly modded daily driver, will see some track time.
Im not sure I completely understand the torsen idea. It supplies torque to both wheels unless one has no traction, then its just like an open differential?? If I got this unit how would it be as far as launching, burnouts, donuts (dry and wet) are concerned, compared to an eaton posi unit. Will this be the same as my stock differential (posi)?
Basically, I want something that will leave two stips when I floor it, hook up good for racing, and be good for a rare donut or two. Its on a high school budget so I'd like to get the Torsen, but if its going to be too similar to an open dif, I mind as well go with eaton. Thanks as usual folks.
Old Mar 20, 2004 | 07:36 AM
z28s's Avatar
I have the torsen unit from slp...its perfect for what you need, i get both wheels at the track and street, the only thing is that you loose you abs because its designed for the cars with the wheel speed sensors at the axels...my abs wasnt working when i bought the car so i wasnt too worried....
Old Mar 20, 2004 | 12:41 PM
MRBoss429x's Avatar
Thanks z28s, thats exactly what I wanted to hear. Can anyone else concur? Whats it like as far as braking is concerned to have no abs in the rear? The front is still fine right? Thanks.
Old Mar 21, 2004 | 07:24 AM
z28s's Avatar
braking is the same, if you want to remove the abs unit you might want to get an adjustable prop valve, although you could do it without one...
Old Mar 21, 2004 | 06:02 PM
rpm4lalo's Avatar
I have 3 channel ABS and the Zexel Torson was put in when I added Motive 4.11's.
This explains why I have had an ABS INOP light that comes and goes.
My question is "Do you only loose ABS in the rear, because when the ABS INOP light is NOT on, I definetley can hit the brakes hard and not lock the front tires up.
Also, when I get a Moser 12 Bolt with 3 channel ABS will this cure this problem with the ABS INOP???
Old Mar 22, 2004 | 05:23 PM
mullettour's Avatar
Not true. My car has 3 channel abs and a factory zexel-torsen differential. You just need a reluctor ring in the differential and a sensor mounted in the housing.
Old Mar 22, 2004 | 05:52 PM
z28s's Avatar
the zexels that are take-offs from slp are from '98-up cars so there isnt a sensor on the top of the differential, so a reluctor ring won't do anything....when i installed mine it looked like the reluctor ring woundn't even fit
Old Mar 23, 2004 | 04:23 PM
mullettour's Avatar
I know what they are from. All I'm saying is it's possible to make it work because my car is a '00 and it has 3 channel abs with a zexel diff.
Old Mar 24, 2004 | 07:54 PM
ROCKN SS's Avatar
I have a '97 with 3 channel ABS, basicaly my undestanding is:
with traction control - 4 channel abs
without traction control - 3 channel abs
Old Mar 24, 2004 | 09:22 PM
dkeers's Avatar
The reluctor ring will fit. I just did it last week when I put a zexel torsen posi in a 1995 rearend.
Dustin
Old Mar 25, 2004 | 06:27 PM
95 WHITE TRANS's Avatar
I think you need a diffrent sized reluctor ring.
NICK
Old Mar 25, 2004 | 10:13 PM
WS6Formula's Avatar
My 96 has the 3 channel ABS & it has a Zexel diff. had the dealer do the install though.
Old Mar 26, 2004 | 02:56 AM
dkeers's Avatar
NICK
I took the stock reluctor ring off of my original worn out posi and put it on the zexel torsen unit before re-installing it. It worked fine for me.
Old Mar 26, 2004 | 02:44 PM
96ltz's Avatar
I think you need a reluctor ring for a 3 series carrier since you had the 2.73s
Old Apr 12, 2004 | 07:42 AM
"White Knight"'s Avatar
What he said^
series 3 reluctor ring, and you will have your abs SLP sells the ring i believe for 20bucks
