comp cams roller rockers
Old Mar 19, 2004 | 10:36 AM
Roadie's Avatar
I got shafted on a set of rocker arms (pardon the pun). I was told these were a barely used set of CC 1305-16s (1.6 pro-magnum rockers for 7/16" studs). When they arrived, it turns out they were not even close to the same thing... And to top it off, parts were missing. The !@#!@ seller wouldn't make it up to me either.
Anyway, these are Comp Cams 1418-16 1.6:1 ratio self-aligning Magnum roller-tip rockers. They all appear to be in good condition. I checked each roller individually. One rocker arm was obviously replaced, but with the same type of rocker. This will not affect their function in any way.
Now, for the missing parts. On top of getting screwed, I felt I couldn't honestly sell these to anyone else without replacing the missing parts. I spent another $40 on brand new ***** and nuts from comp cams to go with them.
These retail for $180 new. I have more than that in them because of that seller. I would like to get $120 shipped for them, but will entertain all REASONABLE offers.
Pics below. The lower right rocker is the replacement one. The 2 bags contain the brand new ***** (1400B) and nuts (1400N).
low res: http://www.lt1.org/other/jpg/1418-16low.jpg
high res: http://www.lt1.org/other/jpg/1418-16high.jpg
Old Mar 19, 2004 | 08:50 PM
Roadie's Avatar
ttt
Old Mar 21, 2004 | 10:47 AM
Roadie's Avatar
Angry
new price -- $120 ??
ttt
Old Mar 21, 2004 | 12:04 PM
TheRedZ's Avatar
Well, I might take them.
Depends on if this other deal goes through or not.
Where are you located??
Old Mar 21, 2004 | 12:53 PM
Roadie's Avatar
I'm in O'Fallon, IL.
I know I don't have a lot of posts here, but just for reference, i'm a senior member and moderator on FAST (F-Body Association of St. Louis -- http://www.fastlouis.com )
Old Mar 24, 2004 | 11:56 AM
Roadie's Avatar
ttt
Old Mar 26, 2004 | 08:27 AM
25th_Trans's Avatar
sent you a PM
Old Mar 26, 2004 | 09:28 AM
Bersaglieri's Avatar
Will they fit a stock LT1 if i get new springs?
-Dustin-
Old Mar 26, 2004 | 10:22 AM
Roadie's Avatar
-Dustin-
With any stock LT1 cam (93, 94-95, or 96-97), the max lift of any of the cams will be at .491" with 1.6 ratio. The stock springs should easily take that... But it definitely wouldn't hurt to throw a set of LT4 springs in there.
I have a sale pending now, but will reply here if they are still available.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
