Whats the best way to put on an intake???
Old Mar 14, 2004 | 04:35 PM
Blown350ZZ4's Avatar
Question Whats the best way to put on an intake???
I am putting on my new intake and want to make sure everything seals properly. I have all fresh gaskets and Permatex Ultra Black silicon. I have a few questions.
1) What is the best way to go about putting on the intake and make sure everything seals properly so I have no oil leaks or vacume leaks?? Is there a method and a property way of applying the gaskets and silicon sealent? Also, do I have to let the silicone settle before dropping on the manifold?
2) What order do I torque the intake manifold bolts and to how many pounds.
Thanks in advance.
Nick
Old Mar 14, 2004 | 06:41 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
see manual for sequence, 35 ft/lbs. use some sort of self locating guide in opposing corners, i used a shortened pencil.
i have always torqued it in increments from 15 ft/lbs - 25 ft/lbs - 35 ft/lbs
also not sure if this post is "advanced tech" hope that helps
sequence (from memory) don't quote me
8 - 7 - 2 - 3 - 9 - 10
front
6 - 5 - 1 -4 - 11- 12
Old Mar 14, 2004 | 07:39 PM
kmook's Avatar
Advanced Tech Moderator
Lets try this in 3rd Gen Tech, thank you.
Old Mar 14, 2004 | 08:46 PM
Marc 85Z28's Avatar
Use quality name brand gaskets.
Toss the rubber end seals. Use the black RTV on the ends, 1/4" bead, and extend the bead from the block onto the heads about 1/2".
Apply small amount of RTV on gaskets around water passages to prevent leaks and to hold gaskets in place on heads while you drop the intake.
Apply thread sealer/RTV on intake bolts to prevent oil seepage.
Let everything sit for an hour so the RTV sets in place.
dawg irocz
Feb 10, 2015 10:33 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
markaubuchon
Jan 14, 2015 01:48 AM
95chwagon
Jan 13, 2015 09:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
