Racing fuel
Old Mar 12, 2004 | 07:56 PM
1stls1's Avatar
Racing fuel
I don't know if right forum or not but, can you run Cam2 fuel in a LS1, just a thought>
Old Mar 12, 2004 | 08:00 PM
PhantomTA's Avatar
Moderator
you wont make any more power..
its a waste of money and may cause you to lose some power
Old Mar 13, 2004 | 08:20 AM
Eliminator's Avatar
When you use race fuel dont you need to upgrade your ign. and coil so the higher oct. gas burns all they way?
Old Mar 13, 2004 | 02:15 PM
Strahley's Avatar
If you are all stock like your sig says, you do not need racing fuel. It would be a waste of money and would probably do more bad than good
Old Mar 13, 2004 | 02:30 PM
1stls1's Avatar
I wasn't looking at running w/ it all the time,maybe just add some on race day.What harm could be done?
Old Mar 13, 2004 | 03:50 PM
stealth2's Avatar
Octane is an expression of a fuel's resistance to detonation. With a stock motor, 91/93 octane is fine.
Old Mar 14, 2004 | 01:10 AM
Gold Z's Avatar
Stealth2 is correct when he said, Octane is an expression of a fuel's resistance to detonation. Most people assume that a higher octane gasoline is a more powerful gasoline and that by running it they will go faster. Unfortunately that is not true. Unless your engine has a detonation problem higher octane fuel won't benefit you in any way. What higher octane does is let you run more timing or more compression, the things that cause detonation. It's the extra timing or the higher compressio ratio that gives you the horsepower increase. The higher octane fuel just keeps the motor from detonating and destroying itself.
Old Mar 14, 2004 | 10:35 AM
hurricaine418's Avatar
octane
ditto, as far as damage, too high of an octane will destroy your cats in short time. (melts your substrate). you will need higher octane levels or ignition retarding if you go forced induction and over do it. superchargersonline.com has a good calculater for that should you go that route.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
mark0006
Mar 21, 2015 12:32 AM
jbrockwell
Mar 14, 2015 08:44 PM
Joes96z
Dec 14, 2014 04:03 PM
