To port MAF or not?
Old Mar 8, 2004 | 02:00 PM
6LITEREATER's Avatar
To port MAF or not?
I did a search but couldn't find a definitive answer. Is it a good idea to port (remove the metal divider) the MAF sensor on a LS1 or not? I know how to port the MAF, just don't know if I should.
Old Mar 8, 2004 | 04:03 PM
FastrDamnit!'s Avatar
Do not port, especially since you've got an A4. Can mess up your tranny as it will cause your shifts to soften up and increase slippage.
At most just descreen.
Old Mar 8, 2004 | 06:35 PM
jakesnake123957's Avatar
Do not do it I did it on my 94 and now I am lookin for a stock MAF!>Jake
Old Mar 8, 2004 | 06:59 PM
edg1957's Avatar
It's a huge debate, I ported my A4 and have been happy with it.
Old Mar 8, 2004 | 07:56 PM
bombd84's Avatar
The reason I wouldnt do it is because the MAF uses the air flow calculations based on the inside diameter of the MAF. When you port it, it doesnt correct for a size change, so it can throw off the ratio.
Old Mar 8, 2004 | 08:20 PM
Greed4Speed's Avatar
I have a ported and descreened MAF. No probs at all. I'm waiting for a dyno day to try it vs a stock one and see about gains, but it sure feels a little more torquey.
Old Mar 9, 2004 | 07:20 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up
I installed "ported" MAF ends on my 2001 Z28 A4, however it was 2 days before I had the car dyno tuned, my vehicle did run ok for the 2 days before I got it tuned. If you have an automatic, I would not do it unless you are going to have it tuned, for the PCM DOES use the MAF + speedometer readings to shift the automatic transmission.
A side note, the Corvette MAF I believe is descreened from the factory.
JMHO
SteveC
Old Mar 9, 2004 | 09:52 AM
rncotton's Avatar
If you're gonna port your MAF, do what I did. I found a guy who installed aftermarket MAF ends and I bought his stock ends dirt cheap.
Now, I've got one set that I've ported, and a stock set complete with screen.
Old Mar 9, 2004 | 11:07 AM
Well, for now I will just keep it descreened.
One more question, is the Corvette's meter tuned for the non-screened sensor?
Old Mar 9, 2004 | 11:17 AM
teke184's Avatar
the corvette unit, typically sold as the ZO6 maf, is larger, has no screen and is calibrated specifically for it's dimensions.
had one on my 96 and noticed a decent top end gain
Old Mar 9, 2004 | 11:29 AM
z28chrizz's Avatar
Only Free mod I didnt do. Too many problems. Certainly dont want to go too lean, and with the IAT mod with the most agressive Fuel/Air mixture the car can do, I dont need the knocking or the worry...
Old Mar 17, 2004 | 06:11 PM
JimMueller's Avatar
The biggest problem is fixing the MAF values in the PCM. Until there's a good method to flow testing the MAF's to correct the table, I wouldn't use anything aftermarket. If you buy a Z06 MAF, just load the Z06 MAF table into your table. It'll have more cells since it goes to a higher frequency.
The ported MAF ends have been reported to cause damage to A4's as a result of the PCM thinking there's less load on the engine - because it's not accurately reporting airflow through the MAF.
Or, switch to speed density
Old Mar 17, 2004 | 09:16 PM
chuck's Avatar
Don't touch it.
If you must, I will trade you a set of stock ported ends AND a set of aftermarket plastic ends for stock ends with a screen. PM me if interested.
Old Mar 18, 2004 | 10:18 AM
stealth2's Avatar
Don't do it. See article in current Chevy High Performance on same.
colts0455
Sep 2, 2015 12:41 PM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 21, 2015 10:21 AM
bunker
Aug 1, 2015 09:47 PM
