sensor on intake
Old Mar 2, 2004 | 07:00 PM
FLIPPINZ28's Avatar
sensor on intake
okay i have a 2001 camaro ls1 engine in my 94 camaro. there is a sensor on the driver side of the intake. with a plugin harness and 2 hoses coming from it one is hooked up the other end is just lying there not hooked up it has vacum to it cause it sucks in a little where does this go thanks abunch
Old Mar 2, 2004 | 10:14 PM
AL SS590 M6's Avatar
Moderator
That's part of the A.I.R. system.
Old Mar 2, 2004 | 10:26 PM
96SFLZ's Avatar
As Al said, that hose goes from the lid to the AIR pump.
If you have a stock lid (or an SLP lid I think?) it should be fairly obvious where it goes. With any other aftermarket lid, you're going to need a little K&N breather filter (to stick in that hose). I dunno the K&N part number but I'm sure you could find one at a local parts store that sells K&N crap. Or you could just buy one from almost any LS1/F-body vendor that sells lids (like Thunder Racing <--- I know they sell it).
Old Mar 2, 2004 | 10:45 PM
FLIPPINZ28's Avatar
i have a 94 camaro with a rigged up intake. but the hose is way to small to fit a small filter on it the hose is a hard hose and is bent wierd looking. one goes into the sensor from the back of the intake it looks like and the other is just hanging there about 4inches and bent weird. any ideas i wouldnt think it went to the lid though
Old Mar 3, 2004 | 05:50 PM
Moderator
In your case just plug it off. You don't need it if you're not going to run an LS1 type AIR system. I took mine all off and plugged it at the back of the manifold. You will have to have the AIR removed from the PCM because it will set a code.
Moderator
Not the intake lid...........the intake manifold.
Old Mar 4, 2004 | 12:15 AM
FLIPPINZ28's Avatar
the air stuff has already been removed so i just plug the little tiny hose off with something it is a hard hose not even a quater inch so is this the right one were all talking about?
Old Mar 4, 2004 | 08:42 PM
Moderator
Yep
Old Mar 4, 2004 | 08:47 PM
FLIPPINZ28's Avatar
awesome thanks
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
99TransAmWS6
Mar 22, 2015 11:00 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Jul 4, 2005 05:00 PM
