need help with TunerCat security error
Old Aug 24, 2002 | 08:19 PM
ryaskovic's Avatar
Question need help with TunerCat security error
I've just purchased TunerCat and I'm trying to do my first PCM read. I:
- run flshread.exe
- enter "stock" as the filename
- enter "1" as my com port
- connect the cable to the ALDL connector and turn the key 'on'
- enter 'p' to start the read
after a second or two I get an error "security violation (0)"
The instructions say to remove power from the PCM for 30 seconds if you get this error. I pulled the PCM fuse for 30 seconds with no change. I pulled the PCM fuse for 2 minutes with no change. I removed the negative battery cable for two seconds with no change. I removed the negative battery cable, went in and took a shower....no change.
Can anyone help?
Thanks,
RobY
95 Z28 M6
OBDI w/OBDII connector
AKM cable that works fine with Datamaster
Old Aug 25, 2002 | 12:31 PM
ryaskovic's Avatar
Post
FYI, I figured out my problem!
I wasn't giving the PCM enough time to boot before hitting the 'p' to proceed with the read. I'd turn the key on and once the fuel pump quit, I'd hit 'p'. That wasn't enough time. If I wait ~8 seconds or so it'll work fine.
RobY
Old Aug 27, 2002 | 03:46 PM
Dr.Mudge's Avatar
Post
Yep, I give it about 5 seconds or so after the beeping finishes etc
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
whitehooptie
Jul 22, 2015 10:25 PM
