anyone with a remote bottle opener, question
Old Feb 13, 2004 | 03:55 PM
Hawk's Avatar
Well, I have the NX remote bottle opener. It works fine, BUT sometimes I have the problem of the valve on the bottle itself getting hard to turn and the clutch in the opener will spin and I can't get the bottle to open or close. I would have to go and turn the bottle open/close by hand and free it, then put that remote bottle opener back on. I tried wd40 on the valve, I hope it works better. Anyone else ever have this problem, I'm just wondering if I just have a sticky valve on my bottle or if this is more common problem. Thanks
Brian
Old Feb 13, 2004 | 05:06 PM
JSK333's Avatar
Yes, I occasionally have this problem.
It started recently. It used to work just fine. So I am thinking it might be time to tighten the clutch up. You might try that and see if it works.
Old Feb 13, 2004 | 08:22 PM
88Camaroturbo's Avatar
Yes....
You need to tighten up the clutch.
I dont have mine anymore cause 1 of my bottles is in the truck for race days...so i have time to open it up...and my other one is under the seat just incase i need to open a can on someone on the street. And its easy to open...
But yes...Just tighten it up...Should be fine.
Sent me a message if you need anymore help.
-Alex
Old Feb 13, 2004 | 10:22 PM
Hawk's Avatar
thanks guys, thats something along the lines of what I was thinking. Since I don't have the directions, can someone give me a brief rundown on the proper way to tighten the clutch, such as where is the adjustment, and how much of a turn I should tighten it, I don't want to break anything. Or better yet, anyone have a scanned copy of the directions??? Thanks again
Brian
Old Feb 15, 2004 | 04:25 PM
gb95zconv's Avatar
When you think its tight enough ...tighten it more....mine is very tight and works great now. Also make sure not to bind the valve opener when you put the top piece in place.
Old Feb 16, 2004 | 09:50 PM
mario595's Avatar
Clarify...
I have just installed an NOS remote bottle opener. I have only bench tested it. I don't understand the problem you are having but it seems to be common. Can you explain again what happens with your bottle opener? Does it happen only to that brand or does the NOS bottle opener do it as well.
Old Feb 17, 2004 | 08:06 AM
gb95zconv's Avatar
Brian
Its very simple to tighten. The clutch\gear has a bolt thru it. Hold the nut with a wrench and tighten the screw....it may take a few adjustments to get it tight enough.
Old Feb 17, 2004 | 08:09 AM
gb95zconv's Avatar
Re: Clarify...
I belive the NOS opener is a silinoid type not a gear type like the NX piece is.
Old Feb 18, 2004 | 10:17 PM
Deadcarny's Avatar
i had the problem too and could not get it right. I ended up just taking it off since the only time my car is run is at the track where I can open the bottle by hand.
Old Mar 17, 2004 | 10:37 AM
JSK333's Avatar
Just wanted to give my update--I did the above and it works perfectly now. One could tell it needed tightened when I went to do it, as the screw was somewhat loose.
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
