Surging at low RPM/Light Throttle
Old Feb 10, 2004 | 07:05 PM
TravisA's Avatar
Anyone else with a supercharged setup ever have any problems w/ surging at low rpm's with little or no throttle applied?
Car has Procharger setup, stock heads, 218/230 cam and forged 355 bottom end with speed pro blower pistons if this helps.
Thanks just wondering if someone has had a similar problem and can point me in the right direction.
Travis
Old Feb 11, 2004 | 12:41 PM
Wild1's Avatar
I've heard about that... I've heard two results:
1 - programming
2 - MAF location
Old Feb 12, 2004 | 10:39 AM
TravisA's Avatar
1 - programming
2 - MAF location
I've moved the MAF to the boost side. There isn't much done to it in the programming department.
Last night i ran a scan while it was at idle and the 02 mv's was under 50mv? Does that mean its running rich and trying to lean it out ?
Travis
Old Feb 12, 2004 | 12:45 PM
Wild1's Avatar
The O2s should be bouncing between .100-.900 If they are stuck or lazy then they should be replaced. How are you testing your O2s? On a DVOM, if you have a Min/Max they should be near the extreme between .100-.900...
Low numbers are very lean.
Old Feb 12, 2004 | 07:08 PM
TravisA's Avatar
I was using freescan and noticed the 02's were under.50 mV's. There was no bouncing back and forth between .100 and .900.
Travis
Old Feb 14, 2004 | 01:39 AM
Blownbird355's Avatar
I think advancing timing at that rpm may help but dont quote me.
Old Feb 14, 2004 | 02:20 AM
Wild1's Avatar
Those O2s sound very suspicious... they shouldn't be still.
Old Feb 14, 2004 | 11:30 AM
2cub49's Avatar
Yes if the 02's are contant they're dead usually.
Old Feb 14, 2004 | 11:45 AM
TravisA's Avatar
Thanks Everyone
I'm gonna change a few things and run a scan to see what happens.
Thanks Again
Travis
RUENUF
Mar 13, 2016 03:39 PM
Noenav
Apr 30, 2015 01:06 PM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
