gas tank removal
Old Feb 6, 2004 | 05:47 PM
Gnboy's Avatar
gas tank removal
how does the gas tank come out I have everything off but the neck of the tank won't come out
changing fuel pump
Old Feb 6, 2004 | 07:00 PM
JAY'S 91Z's Avatar
Had to do it twice last summer!!! The neck is a pain, it took two of us. One under the car and one with a big screwdriver to very gently "pursuade" the neck while the first keeps twisting and turning it from underneath. Be Patient, it WILL come out. I have been told that the neck can be bent quite a bit without breaking the bead off the tank. I didn't chance it. You have to move everything out of the way, then let the rear end drop to get the clearance. Takes me about an entire afternoon to drop it, work on it, then replace everything. Good Luck!!
Old Feb 6, 2004 | 10:33 PM
Gnboy's Avatar
did it! I bent the neck car runs like a champ w/ the new pump
however its not that easy getting it back in eitheresspecially when your by yourself
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
blac94Z
Nov 24, 2014 07:12 PM
