timing retard with powerdyne?
Old Feb 2, 2004 | 07:54 PM
blueta's Avatar
How do you retard the timing with the powerdyne kit? My old vortech had the adjustable **** mounted in the car. Also, I've never set rev limiter on these ignitions (the crane one with the kit) It says rpm X100 and has 2 dials. Am I missing something?
Old Feb 3, 2004 | 09:55 PM
canbaufo's Avatar
The PD kit doesn't come with one. The dials you are looking at on the ignition box are to set the rev limiter. One is thousands of rpm and the other is hundreds. You will need a separate Crane TRC-2 boost controller which will proportionally retard timing with boost. Jegs or Summit has them. Just be sure to get the right one....there are different versions of timing retard controllers from Crane. Just make sure it is compatible with whichever Crane ignition you have. If you have the Crane HI-6 I believe the TRC-2 is the correct one but check to be sure in the manual.
Old Feb 4, 2004 | 08:49 PM
blueta's Avatar
Yeah, that's what I thought. I just sold my crane with the retard because I thought I was done with forced induction
RUENUF
Mar 13, 2016 03:39 PM
mikey4play
Mar 15, 2015 11:45 AM
nophix
Nov 30, 2014 10:26 PM
ScottZ
Mar 3, 2004 01:34 PM
