Turbos and head porting ?'s
Old Feb 2, 2004 | 10:39 AM
4-play's Avatar
Using stock LT1 heads with a turbo, where should I concentrate my efforts when porting and valve sizing? I considered porting both in/ex ports but stepping up to a new seat and a 1.6 on the exhaust and staying with a 1.94 or 2.00" on the intake. This way the exhaust gets a bigger seat to help dissipate heat and a larger valve to expel the spent gases. I'm not really worried about getting air in! lol
Old Feb 2, 2004 | 05:11 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
and you really dont need to worry about getting air out, if you arent worried about getting it in.
you are thinking backwards, if you go with a big exhaust valve there will not be very much seat left. I would stick with the traditional 2.00/1.56
Old Feb 2, 2004 | 06:29 PM
4-play's Avatar
Jordan, I was talkin about using a new seat for a 1.6 valve. Do they use the same size as the 1.5 and then just machine it to accept the larger valve? Also, I figured a ported intake "port" and a 1.94 valve would be enough with a turbo. I thought the hard part is getting it out!
Old Feb 2, 2004 | 06:39 PM
No, blowers have issues with getting it out.. turbos work at semi equal pressures, so the motor functions closer to a NA motor.
If you are gonna spend the cash to go with a bigger seat, I would get some AFRs.
Dmonty
Jun 2, 2015 11:19 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Killer94z
Jan 13, 2015 12:06 PM
