my REVERSE is F'd up!!
Old Jan 27, 2004 | 12:46 AM
ADAMLS1's Avatar
I need some helpy here. Someone please!
When I shift into 'reverse' it just pops right back out. I have to shift into it really hard for it to stick. If it doesn't go in right it makes this weird *** noise and pops right out of gear. It takes like 5 or 6 tries before I can get it to stick. Is this the transmission or the shifter or what??? Any suggestions, solutions, or donations maybe. My warranty is gone. Every other gear is fine.
If the description didn't make too much sense..then sorry. I can try and explain it better maybe.
Old Jan 27, 2004 | 12:50 AM
mullettour's Avatar
My guess would be something with the clutch not releasing all the way causing it to be difficult to engage. Since there are no syncro's in reverse but there are in every other gear it would be the only one it's noticable in if the clutch is barely dragging just enough to spin the input shaft.
Old Jan 27, 2004 | 11:58 AM
1badLS1M6's Avatar
Try letting out the clutch very slowly while pushing it into reverse. My car does this everytime when its cold. Mine will not go into reverse unless you let the clutch out a little. I"ve heard others say theirs is like that too, so try that.
Chris
Old Jan 27, 2004 | 12:33 PM
00LukeyWS6's Avatar
I never have problems with mine, but if you are using an aftermarket shifter it might be set incorrectly, I would check into that and like the others said that it might be the clutch. How many miles do you have on that clutch?
Old Jan 27, 2004 | 01:21 PM
ADAMLS1's Avatar
I've tried letting the clutch out as slowly as possible and still nothing different. Sometimes I cant even get it into reverse gear at all. That noise it makes is horrible though. I feel like Im torturing my girl.
I have 26,256 miles on the clutch right now.
Old Jan 28, 2004 | 03:34 AM
stk350's Avatar
Try putting it in 1st gear then reverse. You don't have to drive anywere in 1rst, just put it in then back it out. It should help.
Old Jan 28, 2004 | 07:36 AM
My84Z's Avatar
I would say the pressure plate. maybe even the pilot bearing but now that i am trying to think i am not sure of the bearing will do anything liek that.
Old Jan 28, 2004 | 11:36 AM
Eric Bryant's Avatar
Yea, exactly.
After a couple friends "buzzed" Reverse in my car while going for 5th, I noticed that I had wiped out the synchro ring. Apparently, it doesn't take many failed attempts to wear it out, which makes it more difficult to engage the gear, which makes it more likely to grind, and then the cycle just repeats itself. If things get worse, you may need to go in the tranny, after making your that your clutch is releasing properly. Fortunately, you only have to pull the tailshaft housing, and fixing the synchro ring is as easy as pulling it off, flipping it over, and reassembling the trans (the ring has teeth on each side, but only one side is used on that particular ring).
Old Jan 28, 2004 | 04:54 PM
GigaMp3z's Avatar
You never wired the lockout solenoid did you?
-Corey
Old Jan 28, 2004 | 09:59 PM
limige's Avatar
-Corey
it's a good idea not to, it's harder to put into reverse that way and prevents you from blowing out the reverse syncro due to a bad lockout solenoid!!
to the original question, it's probably the syncro giving out. the reverse syncro can be flipped around to use the other side, you only have to pull off the tail of the housing and your spedo gear and stuff, if you can rebuild a motor you probably can flip the syncro, if your not that experienced have someone else do it.
Old Jan 29, 2004 | 07:30 AM
Nope - there's little room for it in the B-bodies, so I didn't install it. I've got no problem finding 5th, but I now test guest drivers just to skip it and go into 6th.
Old Jan 29, 2004 | 03:20 PM
ADAMLS1's Avatar
what causes a syncro to get messed up? in my case..the reverse.
Old Jan 29, 2004 | 05:32 PM
limige's Avatar
either not having it fully engaged when you let out the clutch or the lockout solenoid failing and you hit reverse looking for 5th.
Old Jan 29, 2004 | 08:39 PM
Fry's Avatar
Fry
I've had this problem ever since getting a new clutch, it's not a real bad thing.....apparently, like everyone says, the syncro, I go into first then reverse and it lessens the impact and makes it easier and a one time thing......so I don't have to "try" 2 or 3 times, I've become accustomed to this and then jamming it in reverse to the point where I can feel it lock in there.
RUENUF
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
dolfan324
Jul 17, 2015 10:34 PM
Beave2780
Jul 7, 2015 06:36 AM
jimlab
Oct 6, 2002 08:37 AM
