12 sec 1996 Trans Am WS6 FOR SALE $9200 OBO
Old Jan 26, 2004 | 08:33 PM
Chris 96 WS6's Avatar
73,000 original miles
Kelly blue book is $9650
What you are getting:
The car (obviously), artic white exterior with dark graphite leather, T-top car. Single disk 10-speaker stereo w/pioneer speakers replacing stock mid-bass drivers in back seat. Automatic transmission w/ trans go shift kit and Vigilante 2800 converter (still has free stall speed upgrade).
Stock 3.23 gears in stock rear end. Corvette Z06 front brakes with red calipers and Z06 pads. Stock rotors/calipers available if you want them.
Stock WS6 suspension including 32mm front sway bar, and SLP 21mm 1LE rear bar.
Stock silver 17” WS6 wheels with BFG G-Force KDWS tires on all fours, about 50% tread left…great all-weather tires. Air conditioning is ice cold.
Engine:
Stock LT1 bottom end, Comp XE 224/230 cam with 114LSA, 1.6 comp pro-mag roller rockers with guideplates and chromemoly pushrods. Set of stock LT1 heads FULLY PORTED by Lloyd Elliot, peak flow 283cfm intake/192 cfm exhaust (flow sheet will be supplied). Stock intake port matched to heads and 30lb SVO fuel injectors. FLP longtube headers complete with cats and off-road pipes. K&N Filter, 160* t-stat. I’ll also throw in the stock manifolds/y-pipe if you want it.
Exhaust is a 3” cutout and a dynomax ultraflow muffler. This is a great sounding car.
LT1 edit for this car including all flash files available for an additional negiotiable cost. Laptop NOT included.
Car will be sold AS IS. There is a missfire I have not been able to trace down, the car will be sold with this problem and you will be responsible for repairing the car yourself. It has shut off on me a couple of times because of this problem but always starts back up. New coil, module & opti have been installed in last 6 mos.
Please e-mail chris@mtfba.org serious inquiries only.
Car put down 362rwhp and runs very consistent 12.30’s at 110 mph WITH the miss problem.
Photos & dealer option sheet available at http://www.chris96ws6.com
Old Jan 27, 2004 | 08:50 AM
ttt
Old Jan 27, 2004 | 10:26 PM
gabez28's Avatar
bump for a friend
Old Feb 3, 2004 | 06:32 PM
Fenster's Avatar
bump again for a friend!!!
oldschool
Feb 9, 2016 09:21 PM
siguy
Nov 27, 2014 10:07 AM
whuzizname
12
Jul 22, 2002 07:52 PM
Chris 96 WS6
Jun 27, 2002 05:03 PM
