Autocross and Road Racing Technique There is more to life than a straight line
Nondirected/Open Topic
Old Sep 8, 2002 | 12:28 PM
#7's Avatar
Post Nondirected/Open Topic
Just would like to share,
Ran Thunderhill park in Willows Ca. again sat.7th. 3miles 15 turns.
I love this stuff,it keeps getting better and better pushing my own envolope.I beat my best time of aug.3rd at 2min.36sec.My best this time 2.28secs,a more consistant 2.30secs.The new Jet stage 2 PCM has done wonders to this car w/my Mods.Gains in all ranges.Got to 99mph on the front straight weeee!!
Do you think my wife gave me the 2 secs off for effort?j/k
One spin out at turn 7,first session(firt lap),cold tires,tire pressure too low.Its going to take some work to get the interior and outside back to Hella Clean.Dirt and weeds inside noooo!!Made air adjustments,warmed tires a little before "gettin it" the rest of the day(what a great day)
But right front caliper was draggin all day,took some meat off the rotor&pad.Nothing to serious.Experienced a hesitation in the motor at high RMPs,but durning the final sesions.At first I'm thinkin the new chip isnt really comunicating well w/ECM.But fuel was getting low,Prob.catching small gaps of air from the fuel being low and sloshing around.It was a little below 1/4 tank.
I'm thinking complete rebuild front brakes,rubber,new bearing assemblies,before Sear Point on Oct.11th.
Those of you that took time to read this,this topic is open for advise, small talk,parts refferals,whatever.You guys are cool see ya. T.
_ _ ______________ _ _
Hella Clean Dark Green Metallic 98 3.8 L60E Coupe:Fast toys Ram Air,Holly filter,Whisper lid,Jet stage2 PCM,160 Thermo,Man.fan switch,Purple ice wetter,Eibach Pros,Koni adjustables,BMR sways,Prothane bushins,Transgo kit,Magnaflow cat-back.National Auto Sport ***. member/student.
Old Sep 8, 2002 | 10:17 PM
LPEdave's Avatar
Post
Congrats on the improving lap times, that's great! I too spent the weekend cleaning out the car. We ran Thill backwards on wednesday, and I ran off the track coming over turn 5. Blasted through the brake markers, lots of dirt and scrapes... Oh well, it's a race car
Regarding your brakes, hubs, etc: I'd disassemble the right front and see what's going on. The caliper shouldn't be dragging on the rotor, and you need to find out why. If something's bent, pad worn to nothing, etc. For the hub, see if you can shake the wheel with your hands on 12 and 6 o'clock (and the wheel off the ground). If it wiggles, then get a new hub. It should be nice and tight.
The JET chip will advance your timing, basically. When you're running the car hard and hot, at high RPM's, advanced timing just gives it that much more likelihood of pinging. I presume you're running 91 octane? If you can pull the chip out for a session, I'd try it, and see if the hesitation goes away.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics, New to Nitrous? Northern California Racing Club
Old Sep 9, 2002 | 01:12 PM
#7's Avatar
Post
Thankx Dave,yeah I'm pretty stoked about the improved time.Since at the begining of this season I was doing 2.59 yuk.
Hmm,There is some movement in the hub on that side,I wasnt that concerned b/c I thought like older/unsealed/not one unit bearings you can have a little movement and be normal/ok.But I'll take yer word for it,I'm swapping both sides.Rightis bad,left ok,but its only a matter of time for the left I presume.
You went off at 5,Was that using bypass or actual turn 5 b/c if it was actual turn 5 up on the hill that I imagine was a little freaky.Took me 2+ hrs. to get my interior clean/back to the way it was.
T.
Old Sep 9, 2002 | 02:09 PM
LPEdave's Avatar
Post
For your hubs, I'd get them at Pep Boys. They're $109.99 down here, and have a lifetime guarantee. Bring 'em in when they go bad, get another one free. Can't beat that deal! I did both mine this weekend, coincidentally.
My off was over the hill. Turn 5 in reverse is pretty wild. As someone described it, it's like the x-games - launch into thin air, turn right up there, then come down and hope your wheels are in the right place
Dave
Novo
Jun 14, 2016 02:58 AM
mmf_1013
Sep 12, 2015 08:56 PM
CARiD
Jul 7, 2015 08:19 AM
gixxer92
Apr 19, 2004 09:55 PM
Daniel_30thZ28
Aug 22, 2002 11:20 PM
