Autocross and Road Racing Technique There is more to life than a straight line
WTF is Bumpsteer?
Old Aug 24, 2002 | 02:33 PM
Compstall's Avatar
Post WTF is Bumpsteer?
I see it all the time but I don't understand what the hell it is. Can someone please explain? TIA
- Brent
~Project 12's DAMMIT!~
'94 Z28, M6, Borla Y-pipe, Flowmaster Cat-Back, Lingenfelter CAI, MSD-6AL, March Pulleys, Hotchkis STB, Spohn LCA brackets, Cutout, G-MAF, straight-pipe'd cat. (for the track only of course , MAC LCA's & Panhard Rod, Susp. Tech. springs, 287 RWHP / 321 FT. LBS.,
member, http://www.teamnwfbody.org
My page: http://camaroz28.cardomain.com/id/compstall
Old Aug 24, 2002 | 02:55 PM
LPEdave's Avatar
Post
Bumpsteer is a change in steering direction as a result of a bump. Basically as your suspension travels up and down, your toe setting changes. So when you hit a bump, the wheel will point slightly differently, and you'll get a bit of steering input (ie, car will want to go a different direction) during that bump. Different suspension setups have more or less bump steer, and of course you'd like your car engineered to have as little bump steer as possible. It's my (unvalidated) understanding that 4-th gen f-bodies don't have much bump steer.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics, New to Nitrous? Northern California Racing Club
Old Aug 24, 2002 | 03:01 PM
#7's Avatar
Post
Compstall,Its a little funny w/660 posts,and your mods.You havnt the info you need
I've found the bump steer tie ends,theres a brief discription@ RK sport,suspension or steering for your car make/model.
I too have considered them after foaming and frying my PS system.I THINK I'LL WAIT FOR A MORE EDUCATED,advise w/ you.
I thought it would eleviate some of the pressure being exerted on the wheels/System.While mashing the speed bearms,on the turns?Sypherical bearing tie rod end
_ __________________ _
Hella Clean Dark Green Metallic 98 3.8 L60E Coupe:Fast toys Ram Air,Holly filter,Whisper lid,160 Thermo,Man.fan switch,Purple ice wetter,Eibach Pros,Koni adjustables,BMR sways,Prothane bushins,Transgo kit,Magnaflow cat-back.National Auto Sport ***. member/student.
Old Aug 24, 2002 | 03:14 PM
Compstall's Avatar
Post
Well, I'm not too much of a twisty road guy myself. I find things out as I go, like most. This is just one of those things I've never found a need for, ~yet.
Thanks for the info though Dave!
- Brent
Old Aug 28, 2002 | 07:46 AM
Norm Peterson's Avatar
Post
Even the straight-line only racers should be concerned about bumpsteer. Front wheels that develop substantial toe as the nose rises under acceleration are only hurting the ET's and mph's. Might not be much, but every 0.001 counts.
Norm
Old Aug 28, 2002 | 02:18 PM
Compstall's Avatar
Post
How much are those kits?
Old Sep 2, 2002 | 10:27 AM
drop top steve's Avatar
Post
the bumb-streer kits I've seen have cheeseco (cheap) ends. I've seen several used ones on ebay, you can get good rod ends (teflon lined) for $40 a pair. They help a lowered car more than a stock ride hieght.
Old Sep 3, 2002 | 11:17 PM
Compstall's Avatar
Post
Where to get 'em???
Old Sep 7, 2002 | 07:56 AM
93zder's Avatar
Smile
$40 a pair!! Sounds pretty cheap to me - where can we buy them??
1993 red M6 Z28; custom control arms; bushings; strut bar; Eibach Pro-kit;17x9.5" OZ Monte Carlo & Bridgestone RE71 275 tires; Mac exhaust; K&N cold air; airfoil; TB bypass; 3.73 gears; KVR pads & rotors; -1 camber alignment
Old Sep 7, 2002 | 10:13 AM
LPEdave's Avatar
Lightbulb
I can hardly wait for all the stories as you guys try to get these things adjusted...
Dave
surreybrad
Jul 29, 2015 02:55 PM
housh
Sep 20, 2002 06:40 PM
jthomas
Sep 6, 2002 03:18 PM
MadKilla
Jul 22, 2002 06:42 PM
BadAssed93Z
Jul 6, 2002 07:13 PM
