Autocross and Road Racing Technique There is more to life than a straight line
WTB: LS1 Road Race brake pads
Old Aug 6, 2002 | 12:20 PM
W2WFIREHAWK's Avatar
Post WTB: LS1 Road Race brake pads
I am looking for new or used brake pads for the front ls1 caliber. Looking for
hawk: blues, HP10, HP12
Wilwood J
Performance friction: 93, 99, 01
Or any other pure race pad
1/2 warn is ok
Email me at MLHILL@usg.com
Mike
Old Aug 6, 2002 | 02:32 PM
BobC's Avatar
Post
I'm planning to get custom KFP pads at this point if the LS1 pad isn't a stock pad. Want to go in with me ordering some? PF won't make any, I've asked twice, and I won't buy Hawk's.
If you want I can bring my spare stock LS1 pads to RA in case you get in trouble.
BobC
Old Aug 6, 2002 | 05:32 PM
94bird's Avatar
Post
Bob,
I'm interested in why you won't get Hawk pads. I've just ordered Hawk HP+ pads from Tire Rack for my C5 upgrade, and if I should cancel the order, I have some time.
Old Aug 6, 2002 | 10:37 PM
BobC's Avatar
Post
I have a friend, a guy that only runs the best, and he had a set of Hawks, and they "chunked" apart. I don't ever want to come into a turn as fast as I can push it, and find out after that I lost brakes due to crap pads.
Your mileage may vary.
BobC
Old Aug 7, 2002 | 01:49 AM
CARGASM's Avatar
Post
I ran hawk blues all last year without a problem.
Old Aug 7, 2002 | 06:18 AM
GM98Z's Avatar
Talking
I have a set of Hawk Blues and Carbotech HP plus ( their latest version) Both are about 50%.......offer??? Also on a side note, I have 2 sets of LS1 rotors 1 GM 1 KVR and a set of LS1 calipers Forsale........Gary
GM01SS/ 2001 SS/ #5747 Rally Red/ mods! /RIP #3/GOD BLESS AMERICA 9-11-01 // FLFB of WNY // WNYFA//
Old Aug 7, 2002 | 12:45 PM
Post
Bob, thanks for the offer on the stock pads, I have a set. I should have enough pads for RA, I was looking to get some more pads for 9-15, alfa club event at RA, and the long race at Blackhawk. We can talk about a group purchase on pads at RA
Gary,
How much do you want for the hawk blues? How bad are they tappered? I will alos email you.
Mike
Old Aug 7, 2002 | 10:00 PM
BobC's Avatar
Post
Since Carbotech uses Hawk friction from what I hear, there aren't many choices. Hawk may have had a temporary problem, I don't know. Amyway, I ordered a set of full race KFP's today for next year's brakes. The only other race pad I've found is EBC. I'll probably try a set of theirs also.
BobC
Old Aug 8, 2002 | 08:48 AM
AZ94FORMULA's Avatar
Talking
I've been told that PAGID in either orange (warmer climate) or black (cooler) are really good racing brake pads. But I'm not sure if they make them for F-bodies.
I'm currently using PF 01's. They are basically full race pads. Lots of noise and brake dust, but they stop great!!!!
I had PF 93's for about 3 races, then they broke down and my cross drilled rotor shreaded them up. They were completely gone, and all the rotor holes were filled with brake pad material.
Kurt
LT4 HOT cam, GM heavy duty timing chain, Crane chromemoly pushrods, Comp Cams "R" lifters, K&N FIPK, BBK 58mm TB, ported intake manifold, ported & polished heads w/ 2.00/1.56 valves, 30# SVO injectors, MSD wires, BeCool radiator, CSI elec. pump, March PP kit, Crane 1.6:1 RR's, Crane ignition, AS&M 1-3/4" headers, SLP cat-back, high flow cat, Hurst shifter, Centerforce DF clutch, SLP flywheel, 3" alum. drive shaft, Strange 12 bolt with 3.73's, HAL shocks, Eibach/SLP springs, Granatelli STB & upper panhard rod, ST sway bars, SLP subframe connectors, Steve Spohn racing torque arm, RLCA's & lower panhard rod, Wolfe Race Craft roll cage, 13" Baer brakes, SLP 17" SS wheels, Auto Meter gauges, LT1-Editor and more... Dyno tested: 370 RWHP w/ 358 Torque http://www.geocities.com/crash607/kurt1.html
Old Aug 12, 2002 | 09:09 PM
Dave B's Avatar
Post
I've used both Hawk blues and now Carbotech XPs. The carbotechs are great on the rotors and stop ok but the Hawks stop better, fade less and last longer.
'97 M6 Kenny Brown SFCs, Koni SA , Eibach Prokits ,LG adjustable PHB , 1LE LCAs , GW upper control arms, K&N FIPK , custom bent Hurst LS1 brakes and Torsen .
Old Aug 13, 2002 | 02:54 PM
megabit's Avatar
Cool
I've been very happy with my KFP carbon kevlar pads. Not cheap $170 for LS1 fronts, but they work good.
Mike
98 Camaro SS
QuickSilver02
Apr 7, 2015 11:12 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
