Autocross and Road Racing Technique There is more to life than a straight line
Alignment settings for Eibach Pro Kit please...
Old Jul 23, 2002 | 06:25 AM
jagsy's Avatar
Post Alignment settings for Eibach Pro Kit please...
Could someone please advise me what camber, caster and toe in I should set the car after installing Eibach Pro Kit on a 1999 Z28.
The car will also have Bilstein HD's, run on 16" rims and be mainly used for the street.
Thanks in advance for your help.
Richard
Old Jul 25, 2002 | 03:27 PM
Dr.Mudge's Avatar
Post
Max caster, -1.0 to -1.5º camber, or greater if you want/can. Zero toe, or toe out 1/16", I went with zero but regretted it (car pushes).
Old Jul 28, 2002 | 06:43 AM
93zder's Avatar
Question
What is the maxumium amount of caster available on our cars. Also, with -1.5 camber, will the tires wear abnormally? I currently run -1, but would like more!
1993 red M6 Z28; custom control arms; bushings; strut bar; Eibach Pro-kit;17x9.5" OZ Monte Carlo & Bridgestone RE71 275 tires; Mac exhaust; K&N cold air; airfoil; TB bypass; 3.73 gears; KVR pads & rotors; -1 camber alignment
Old Jul 28, 2002 | 10:43 AM
LPEdave's Avatar
Post
You can get about 3.5 degrees of caster, maybe a touch more. If your tires are wearing even with -1 camber, then sure, try -1.5, though it's pushing it for a street setup.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics, New to Nitrous? Northern California Racing Club
Old Jul 29, 2002 | 02:12 PM
Dr.Mudge's Avatar
Post
Like Dave said, I got around 3.5 caster. Stock ride height cars I believe can get around 4.5, most people just flat max it out, whatever they can get (maybe not most people, but many prefer it).
Dec 1, 2014 08:08 AM
silver97Z
Sep 11, 2002 03:17 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Z28STYLE23
Aug 17, 2002 07:40 PM
Z28STYLE23
Jul 19, 2002 11:29 PM
