Changing Clutch
Old Jan 19, 2004 | 01:52 AM
Billy_the_kid's Avatar
Changing Clutch
Well I am changing my clutch and found that the most difficult part of this so far is the two top bolts on the bellhousing. What would be the best way to take them off. I am also going to take off the oil pan so I can clean it because its previous owner did not change the oil often and it's always very black. I am also going to straighten out a dent the oil pan has. I am considering an over-haul, but with a busy schedule I can't afford to lose the car. If anybody can help me with the bellhousing on tips on how to take those two top bolts off please help me out!!! Any suggestions that you all have please tell me. I would really like to know.
Old Jan 19, 2004 | 03:55 AM
rskrause's Avatar
Moderator
Long extensions and a "wobbler" socket (a socket with a U-joint) like this one: http://content.sears.com/data/produc...196000-190.jpg
Rich Krause
Old Jan 23, 2004 | 01:14 AM
limige's Avatar
there's 2 ways,
one is after you pull the crossmember and shifter, use a prybar or peice of wood to pry the trans toward the passanger side as you get your socket on it.
the other is to unbolt your exhaust, this will allow the motor to drop down way more!
as stated above you need a 3ft extension and a 14mm 6 sided socket with a universal joint, breaker bar and pipe if needed. lol
Old Jan 23, 2004 | 04:53 PM
Pasky's Avatar
Sup guys, this is his brother in law, i've been the one under his car and I busted the hell out of my thumb using a swivel extension and trying the wobbler.
Im thinking maybe we can lift the engine front the front by the accessories with a jack and have the back of the engine point down about one more inch enough to get that top drive side bolt. If not, I suppose the exhaust is coming off.
Old Jan 23, 2004 | 08:42 PM
Bud M's Avatar
I had to do both, pull the y pipe and lift the motor at the pulley to get the tranny out but that was with the bellhousing attached.
Old Jan 23, 2004 | 09:24 PM
limige's Avatar
it takes some practice and a good swivel that doesn't drop the socket down all the time but it's a peice of cake once you do it once.
Old Jan 23, 2004 | 09:28 PM
rskrause's Avatar
Moderator
Yes, you really have to tilt the motor. Forgot to mention that.
Rich Krause
MyfateZ28
Jun 19, 2015 03:42 AM
anmar A
May 2, 2015 06:59 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
