Rear-end lubrication level question.
Old Jan 18, 2004 | 04:54 PM
stars1010's Avatar
Question Rear-end lubrication level question.
I decided since the Camaro has had the same fluids in it since it rolled off the line 9 years and 128,000 miles ago and the gasket is leaking a bit that its time to change it out. I don’t want to spend a ton of cash. I know the gasket is about $7 but I have no clue what kind of oil/fluid to buy or how much. Help please!
Old Jan 18, 2004 | 05:11 PM
Camride's Avatar
I believe it's 85W90 gear oil that you're supposed to use, along with some GM limited slip additive. Or if you use synthetic gear oil you don't need the limited slip additive. The gear oil comes in a squeeze bottle thing, and after draining the fluid and putting the new gasket and cover on, you just open the plug on the side and squeeze it in til it starts coming out. Then plug it back up and you're good to go
Old Jan 18, 2004 | 05:12 PM
stars1010's Avatar
they have this stuff at auto zone right?
Old Jan 18, 2004 | 05:13 PM
ssbowtie1's Avatar
Yes, don't forget the posi additive, you can get it from gm or autozone.
Old Jan 18, 2004 | 05:28 PM
Inutero's Avatar
Old Jan 18, 2004 | 06:36 PM
Joe Bellman's Avatar
Failure to put the additive will cause the rear end to make noise and cause you problems.
I think you will need 2 quarts to fill the rear end. Just keep adding fluid until it starts to run out the fill hole. Just like when you tighten the bolts on an automatic transmission, don't over tighten the rear end bolts or your gasket WILL leak. Putting a little RTV on both sides of the gasket will help it seal better also.
Old Jan 18, 2004 | 07:25 PM
lil_mikey69's Avatar
I suggest **** EZ.
Old Jan 18, 2004 | 07:41 PM
Musix's Avatar
Originally posted by lil_mikey69
I suggest **** EZ.
My cousins nephew got back from active duty in Korea and says that the hookers over there prefer Vaseline over KY.
Old Jan 18, 2004 | 07:53 PM
Don't they know peterolum based lubricants destory the deliacte latex condoms!?
Old Jan 19, 2004 | 06:51 AM
Camride's Avatar
Only if you use dyno oil. I used Amsoil in my rear-end and drove it for 3 years without a peep or a problem. You can still use it if you want, but it won't hurt if you don't as long as you go synthetic.
Old Jan 19, 2004 | 07:03 AM
Shockwave's Avatar
Lounge Moderator
Grrr. You know this belongs in the tech forums.
Moving to V6 tech...
Old Jan 24, 2004 | 06:02 PM
raceryan's Avatar
Wink
V6 tech???
Don't you mean Drivetrain???
blac94Z
Nov 4, 2015 01:59 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
drt
Sep 27, 2015 04:39 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
