cooling fans won't kick on
Old Jan 2, 2004 | 05:43 PM
Hershball's Avatar
My fans won't kick on, any ideas why????
Old Jan 3, 2004 | 01:37 AM
InjectedSS's Avatar
Re: cooling fans won't kick on
Check the fuse block under the hood. There will be a fuse called FANS/ACTR it's like 10AMP
Then you can start checking the relays if the fuse doesn't work.
Old Jan 5, 2004 | 07:47 AM
badblackta's Avatar
The cooling fans could be a couple of things. First, it could be a fuse. Second, flip the ac on for 5 seconds then flip it off. You should then here the fans running.
Old Jan 5, 2004 | 11:55 AM
Hershball's Avatar
what does it mean if the fans don't kick on after the AC is on for 5 seconds?????
Old Jan 5, 2004 | 12:41 PM
badblackta's Avatar
Hey what I meant was that on 1993s the cooling fans will not come one until like 275 degrees, unless you turn on the ac because it uses the cooling fans. I dont know what year your car is but that was my first thought because I have the same problem. But if you dont have a 93 then it could be a relay or a fuse, or your fans just crapped out but I doubt that is what happened.
Old Jan 6, 2004 | 09:34 PM
Hershball's Avatar
I have a 95 z28, the fans just won't kick on, I'll have to check the fuse box.
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
IrocSS85
Jul 18, 2002 10:35 PM
