spohn torque arm which to get
Old Dec 30, 2003 | 09:10 AM
krazwag's Avatar
which torque arm (rod ended or poly bushing)should I get for street driving and some track time ( 10 times a year) Noise isn't really an issue .
Old Dec 30, 2003 | 09:50 PM
94z'sson's Avatar
a solid rod end will make noise every time it shifts gears
but it will be stiffer and handle better and it isnt as loud as people think
i wouldnt use rubber there because the rod end it only a little more and who knows what that bushing costs to replace it (i am asuming you are talking about a spohn product)
you will be happy with a solid rod end so go ahead and get it
Old Dec 31, 2003 | 06:41 AM
rskrause's Avatar
Moderator
Poly, no question in my mind.
Rich Krause
Old Dec 31, 2003 | 06:51 PM
fastcamz28's Avatar
I have the poly and love it! Very quiet except over bad bumps. Added stiffness to an already stiff suspension. My car is a daily driver w/ infrequent track visits planned for spring. If you do a search you will find alot of comments about the noise factor w/ the rod end as opposed to the poly mount. Good luck!
Old Jan 2, 2004 | 08:12 PM
EDS Z28's Avatar
I have the spohn adjustable torque arm with the poly bushing and integrated driveshaft loop. It is very, very solid, indestructable. It does hit the top of the driveshaft tunnel on some bumps. I am going to have to clearance the tunnel in order for it not to hit. The build quality is excellent.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
