Power Windows
Old Dec 15, 2003 | 03:21 PM
pillow76's Avatar
Power Windows
ok, so i have this 2000 z28. about a year ago, i noticed that when i would lower my windows, it wouldn't go back up. i'd have to wait a few minutes (too cool something off?) in order to have the window go back up. it happened a few times on the passenger side but the passenger side is fine now. however, as time went by, i'd have to wait longer and longer in order to raise my driver side window.. now, it doesn't even go up or down. i don't think it's the motor mechanism, it kinda seems like something was overheating. is there a quick fix? please help thanks!
- seb
Old Dec 16, 2003 | 03:16 PM
z28jaz's Avatar
Usually when the motors wear out they do overheat and get shut down to cool off. That sounds like what is happening to you and if that is the case the only real solution is to replace the motor.
Shoebox has some good info on his site as well.
Old Dec 18, 2003 | 03:21 PM
99blackSS's Avatar
That has to be the motor. You can do the install yourself and save hundreds. If you do it yourself the only cost is the window motor. Here's simple instructions on the easiest way to replace the window motor.
Old Dec 18, 2003 | 08:55 PM
PaulN64's Avatar
it's not that difficult to do. I actually replaced my driver side door today, was gonna do the pass side but didn't have time. I have sound deading on my door and it took more time to take that off so I can drill the rivets than replacing the motor itself. I say about 30 min, if that, to change and replace a motor
Old Dec 19, 2003 | 09:28 PM
Shawnster95Z28's Avatar
I replaced mine with one from Advance Auto Parts for $50 and it had a lifetime warranty. It's a good thing cause I've put 3 different motors in it. Next time I'm gonna get the OEM and see if I have better luck with it.
Keenan
Jan 19, 2023 12:24 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
