Figuring out gears in used car I am buying
Old Dec 10, 2003 | 05:59 PM
Charlie Streetman's Avatar
Hi,
I am buying a 95 Formula M6 on Saturday. It has either 3.73s or 4.10s in the car, the guy wasnt sure since he bought it used at a lot that way. He thought he had 3.73s. He said that one time using a GPS with the speedo showing 80 the GPS was showing about 65, does that make is sound more likely like a 3.73 or 4.10.
If that isnt enough info, is there a way to figure out what gears are in the car without having to get into the rear end. Somebody said there is some formula, by turning the wheels and counting the revolustion of the axle or something. But didnt get the full explanation.
Thanks,
Charlie
Old Dec 11, 2003 | 12:14 AM
90rocz's Avatar
Yeah, mark a white line on the tire and one on the driveshaft. Rotate the tire once, and count how many revs the drive shaft makes, noting the starting and ending point of the line on the driveshaft. EX....3-3/4 shaft turns in one tire rotation = 3.73's
Old Dec 11, 2003 | 07:00 AM
my94blackz's Avatar
get a friend family member or something tell them to hop in their car take off up the free way tell them to do 70 and with you riding beside them in 6th this is what should happen
1600=3.42
1800=3.73
2000=4.10
2300=4.56
Old Dec 11, 2003 | 09:56 AM
Great guys, I appreciate the info.
That is just what I needed.
Charlie
Old Dec 11, 2003 | 06:30 PM
JoeliusZ28's Avatar
http://www.f-body.org/gears/
I dont think you can figure it out with the above since your speedo is off, but Ill post it anyways. I found out I had 4.10s with this, when I thought I was stock.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
97SSdude
Dec 31, 2014 07:43 PM
ChrisFrez
Dec 7, 2014 06:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
