Motor break in with procharger?
Old Dec 10, 2003 | 05:47 PM
blk95zm6's Avatar
Should i break in the motor first,or go ahead and install the procharger when i put in the fresh longblock?
I'm concerned about break in debris and regular oil in the Procharger....They want you to run synthetic oil in the sytem and this is a p600b that's fed oil from the motor.
Thanks guy's...
Old Dec 10, 2003 | 06:11 PM
95 Silver TA's Avatar
When we did my 383, I broke the motor in first. I ran the motor for 20 minutes and then pulled the filter out and changed the oil (dyno oil) then I did it again after 500 Miles. After the 500 Miles, I started to "enjoy" the 383 NA, later when I got the 50# injectors, we installed the blower. I drove the car up to Bryan at PCMforless and swapped in 50# injectors and had Bryan Street tune my car.
I would suggest that you break the motor in first before putting the blower on there.
Thx,
Claude
Old Dec 10, 2003 | 07:09 PM
RCF925's Avatar
You would be all right running the blower, But just don't be going into boost until your rings are seated. I've put 2000 miles on my new 385 with the blower and didn't go into boost until I had about 800 miles on it and everything is fine, I guess it just depends if you have the disipline to keep your foot out of it.
Old Dec 10, 2003 | 07:28 PM
blk95zm6's Avatar
I suppose 500 miles of dyno oil won't kill the blower....Thanks.
Old Dec 10, 2003 | 08:55 PM
Tony Danza's Avatar
95 Silver TA-
Where is bryan at PCMforless?
Old Dec 11, 2003 | 11:09 AM
marshall93z's Avatar
nc i think...
Old Dec 11, 2003 | 11:15 AM
94SLUG's Avatar
I let blower and motor break in for 1000 miles at same time and I changed the oil 4 times.
Old Dec 11, 2003 | 03:51 PM
Mike383LT1's Avatar
break in
put about 100 miles on mine then put it on the dyno changed oil 3 times before no problems
Old Dec 11, 2003 | 08:22 PM
He is located in:
5118 Allentown Pike
Temple, PA 19560
Here is his email addy and phone number:
Programmer@pcmforless.com
Phone 610-685-8871
Its really worth the drive, and Since I brought my friend with me to tune his car, Bryan only charged us 150.00 each for our STREET tunes. He actually sat in the car with his Laptop and tuned the car while I was driving. It may not be as great as dyno tuning with Wideband 02s but for the price it will be a lot more accurate than Mail Order tuning.
Hope that helps,
Claude
D1SC383LT4
Jan 1, 2016 01:56 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
